hey guys got a question.
Discussion in 'The Hokey Ass Message Board' started by corpsewheelie, Jun 16, 2011.
  1. corpsewheelie
    corpsewheelie
    Im looking for a rear end for my 1930 model a project i was told a 8" out of a mavrick would be good, for those of you who have done this or know, what other options would i have?
    thanks for your help
    i also found this from a 70 mustang would this be ok?
    http://sfbay.craigslist.org/eby/pts/2431657861.html
    [​IMG]:)
    -Lou
  2. kendall66
    kendall66
    from iowa
    hi, post this same messsage at the ford barn, those guys would know......good luck with your project.
  3. hotroddon
    hotroddon
    the Maverick rear end is the perfect width for a Model A. And the 8" will be plenty strong
  4. zman
    zman
    from Garner, NC
    yeah so the same people can answer over there... lol...
  5. metalman
    metalman
    Hard to find nowdays but the 57/8 Ranchero/ wagon 9" is a good fit, real close to the Maverick. Maverick 8" been a good choice for years (they are getting harder to find), not many V8 capable rears narrow enough for an A, more so if you run fenders. That why most rod shops sell 9" housings narrowed to fit an A. The 70 Mustang would be a little wide.
    BTW this IS a better forum then the Ford Barn for questains like this, Ford Barn is suppose to be for stockers, HAMB for hot rods.
  6. Model A Gomez
    Model A Gomez
    Maverick is a good choice, don't need a 9" unless you're going racing with serious horsepower
  7. corpsewheelie
    corpsewheelie
    thanks for the answers guy, im building a hot rod out of this thats why im here. im one of those guys who doesn't believe in stock haha, ill have a bunch of questions that will pop up, you must excuse me this is my first hot rod build, i come from a long history of auto cross and i built a mean 65 GTO drag car when i was younger.
    -Lou
  8. corpsewheelie
    corpsewheelie
    i might do a blown 350 later on down the line but for now ill have a mildly modded 350
  9. carcrazyjohn
    carcrazyjohn
    from trevose pa
    All I have is 8 Plenty strong enough and width should be close.If you have to narrow one side its not a big deal Just need another short axle ,If your going fenderless its perfect and no need to narrow......Who needs to extra bodywork anyway ,Sell the fenders and dump the money back in your car................
  10. corpsewheelie
    corpsewheelie
    thanks john, i am going fenderless
  11. A Rodder
    A Rodder
    I have an 8 inch in mine and it is plenty strong gear and axle wise, but my housing has to be bend outward slightly as I have had 5 bearings in it and two different sets of axle shafts and in total I have had 3 shafts walk out on me at highway speed. Now I have a 9 inch out of a 59 edsel that should be in it this fall. For now it is a low speed city car.
  12. Ghost28
    Ghost28
    If you can find one an early ford bronco 9 inch mid 60s has the right width and usually has a 4.11 rear gear. They are 28 spline and have 5 by 5 1/2 bolt pattern.
  13. carcrazyjohn
    carcrazyjohn
    from trevose pa
    I made the mistake of narrowing my rear for my A and then I added spacers ,Pushing it out 2 inches ,So I basically narrowed my rear to get 2 inches out of it what a waste of time ,Narrowed it 4 spaced out 2 and that leaves an inch on each side ,The 32 with fenders I had to do 4 and pack out ,Just so it fit..Rear in truck is 64 or 5 and car is 69 mustang 8 inch.......Back spacing of wheel is important and body roll
  14. corpsewheelie
    corpsewheelie
    thanks ghost, thats something else ill keep an eye out for
  15. corpsewheelie
    corpsewheelie
    what about a 64 1/2 mustang rear?
  16. Johnny Speedster
    Johnny Speedster
    from Atlanta
    We use a lot of the Ford explorer or Mercury Mountainer 4x4 rear ends. Perfect width ,8.8 373 gear, LS and has disc. not traditional but work really well.
  17. The Fairmont rear also works real well. If you need stout early bronco is a good choice. Jeep rear is also a good choice, the weak link being the axle key but that can be over come pretty easy.
    While I'm thinking about it 10 bolt out of a V-8 Box nova will work. Also 10 bolt out of an early S-10 that are cheap and will hold up well under a light bodied car.
  18. 31Apickup
    31Apickup
    The Maverick rear is perfect for a full fendered Model A at 55" from the wheel mounting surfaces. An early bronco is around 58". If you are going to channel the car, you'll need a wider rear than a Maverick.
  19. Mark H
    Mark H
    from Scotland
    I'm using an 8 inch from a '65 Mustang on my 'A'.Width is good though I'm not using stock fenders so not as critical.
  20. zman
    zman
    from Garner, NC
    Granada's are also a good source for rears in that width range.
  21. corpsewheelie
    corpsewheelie
    I probably should have stated that before, the car will be channeled
  22. Tri-Power
    Tri-Power
    from Memphis
    I have an 8" in my roadster and it has taken mucho abuse with no problems. Because of my luck with the 8" in this car, I decided to put one in my current truck project.
    I found a used low numerical ratio open diff, and found out very quickly that used 8" posi units are non existent. And the new parts for an 8" are expensive. Over $1000 for posi,ring and pinion, and bearings.
  23. Deuce Roadster
    Deuce Roadster
    Then by all means go with a 9 inch Ford. Width is not as critical if you do not have fenders. 58 to 60 inches wide ( measured this way ) is ideal :) The 9 inch Ford has a vastly better selection of factory Ford gear ratios and better aftermarket support also ... in addition to being stronger.
    The ever popular 57/58/59 Ford rear end has been the #1 choice for years. Here is a list of rear end widths ( Ford type ).
    Because you are going the channel the Model A ... I would try and find the very common mid to late 60's Ford pickup rear end. Strong and easy to find and the width is good for a channeled car.
    65-66 Mustang 57.25 inches
    67-70 Mustang 59.25 inches
    71-73 Mustang 61.25 inches
    77-81 Versailles 58.50 inches
    74 Maverick 8" 56.50 inches
    75 Mustang II 8" 57.00 inches
    67-73 Mustang, Torino, Ranchero, Fairlane 9" 59.25 inches to 61.25 inches
    57-59 Ranchero and station wagon rears, 57.25 inches
    66-77 Bronco 9", 58 inches
    77-81 Granada/Versailles, 58 inches
    67-71 Comet, Cougar, Mustang, Fairlane, 59.25 inches
    71-73 Mustang, 61.25 inches
    64 Falcon 58 inches
    67 Cougar 60 inches
    67 Fairlane 63.50 inches (coil springs)
    72 Ford Van 3/4 ton 68 inches
    73-86 65.25 inches
    57-59 Ranchero and station wagon 57.25 iches (narrowest 9" housing)
    66-77 Bronco 58 inches but has 5-on-5 1/2 inch diameter bolt circle
    67-73 Torinos, Rancheros, Fairlanes 59.25 inches or 61.25 inches
    67-71 Comets, Cougars, Fairlanes 59.25 inches
    Where to find the 9" rear axle
    67-73 medium and big block Mustangs and Cougars
    66-71 Fairlanes, Torinos, Montegos, Comets, and other Ford intermediates
    with big blocks
    57-59 V8 Fords and Mercurys
    77-81 Lincoln Versailles & Trucks
    I have the early 9 inch Bronco under my 32 Ford roadster ( with fenders ) and a 57 Ford 9 inch under my 32 Ford 3W coupe ( with fenders )
    With a channeled car ... I would try and find a mid 60's to late 60's Ford F-100 rear end. The width would be good for a channeled car and the F-100 rear end is strong and easy to find. Even the brake parts are easily found and purchased reasonably.
  24. corpsewheelie
    corpsewheelie
    thanks for all of the support guys! I really appreciate all the help you guys have given me so far and really look forward to being a part of this forum.
  25. MUSALP73
    MUSALP73
    from ankara
    Can you give me the dimensions of this body? thanks
