Hey Rocketeers!
Discussion in 'The Hokey Ass Message Board' started by Wolfie, Aug 30, 2006.
  1. Wolfie
    Wolfie
    I got a four barrel Olds intake manifold with casting #567184 and I need to know if this will bolt on to my 303 without any problem...................Wolfie :cool: :cool: :cool: :cool: :cool:
  2. Paul
    Paul
    Editor
    lay your new manifold gaskets on the port flange...
  3. yorgatron
    yorgatron
    the short answer is no.;)
    that is the 1956 Olds 4 bbl.
    not only are the ports too large,but the manifold dips down enough to require a valley pan that is concave,rather than convex.
    if you can get hold of some #10 cyl.heads and the correct valley cover it would work just fine.
  4. Dago 88
    Dago 88
    Forget it Wolfie, It won't fit. Just sell me your car.
    Cheers Dago (Charlie) :p
    PS Corrine says Hello :D
  5. Wolfie
    Wolfie
    NOPE!!! CAN'T SELL YOU THE CAR, BUT I WOULD LIKE TO MAKE ATRIP "DOWN UNDER" AGAIN SOMEDAY!!!:cool: :cool: GUESS I'LL HAVE TO GO BACK INTO THE DESERT AND FIND A DUAL QUAD SETUP!!! WOLFIE
  6. Wolfie
    Wolfie
    Thanks For The Info Gang!!! You've All Been A Big Help!..........wolfie
