Hey, what's that smell...
Discussion in 'The Hokey Ass Message Board' started by HeX, Dec 23, 2003.
  1. HeX
    HeX
    I HAVE to re-locate the gas tank in my '57 p/u...
    Alright, maybe "have" is a strong word but the fumes were getting to me...
    What do I need to look out for when moving it? I know I need to look for clearance of the obvious (rear end, drive-line, exhause) but what else? Can I simply measure the opening and get a late model tank that will fit the opening and fabricate some mounts?
    I need help.
    Thanks.
  2. HeX
    HeX
  3. TINGLER
    TINGLER
    Here is a link for putting a mustang tank in the back of a ford truck, but the same principles apply. Mustang tanks are cheap and will probably work for your application.
    HERE IS THE LINK:
    GAS TANK LINK CLIK HERE
    Hope this helps.
    JT.
  4. burndup
    burndup
    from Norco, CA
    I wimped out and put the biggest moon-style tank in the bed of my truck... and I can still haul stuff with it! Not having a gas gauge has bitten me in the ass ac oupla times tho...
  5. I used a 66' Mustang gas tank im my 29 Model A Pickup with a 69' Dodge Charger gas cap in the bed. [​IMG]
    The tank is flat on top because it served as a trunk floor it the "Stang" and it can easily be adapted between the rails of your pickup. [​IMG]
    Your biggest challenge will be the filler neck and cap...! [​IMG]
    Good luck!
    Mark
  6. HeX
    HeX
    THANKS!!!!
  7. 41sled
    41sled
    from Orange, CA
    A question for you beer gods.. How many gallons would it fit in a nice big keg?
  8. burndup
    burndup
    from Norco, CA
  9. skipperman
    skipperman
    I've used the mustang tanks in a a LOT of rods.....have one in my 54 stude.....easy to mount and get senders,etc. for....you can solder up the original fill location and put it where ever ya want.......IF***IF ***IF --ya know how to do it SAFELY !!!!! They come in various gallonage too...only the depth changes.....get 'em in Cougars,etc, too............cheap and EASY !!!!
    Jersey skip
  10. zman
    zman
    from Garner, NC
    70's Blazer tanks work. Fit real nice. Just have to remove the spare tire mount.
  11. OGNC
    OGNC
    I got the one for my 60 from No Limit Engineering. I got part number TNK-A and it is a 21-galon tank. The rear crossmember has to be moved (Just weld in a section of box tubing in the very back of the frame and remove the stocker). It comes with a sending unit and everything. Now you'll have room for a wall of subwoofers behind the seat so you can blast the new 50 Cent joint, yo! LOL
    CLICK THE LINK!
    www.nolimit.net
  12. DrJ
    DrJ
    [ QUOTE ]
    [/ QUOTE ]
    Actually a full keg is 30 gallons, what frat boys and beer bars usually buy are 1/2 kegs, 15 gal.
  13. Rude Dude
    Rude Dude
    Hex this is how I did my tank. I relocated tank to the rear bought a repo gas tank on ebay from 67 mustang they are inexspensive new I paid $60.00 better than no limits $400.00 . I drilled the ribbets out on rear cross member and moved back. After fitting the tank have some of the ribbets need to be replaced after with grade eight bolts cause they hold spring hangers. The modification to tank was to drill new hole for sender on top of tank done with hole saw for sending unit (cut down Stock unit) taking round excess material and welding up original mustang sender hole. Some slight trimming is done on frame less than 1/8 Hope this help sorry no pics
  14. 41sled
    41sled
    from Orange, CA
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    Perfect.... I think itta be a bit too big for the trunk.. How about cutting the trunk so the keg can fit snug right between. like half way in the trunk , half way under neath... Not a bad idea, i would have to say...
    steve [​IMG]
