Heya Techies-Removing a stripped brake bleeder-Any Ideas??
Discussion in 'The Hokey Ass Message Board' started by Spooky, Dec 13, 2003.
  1. Spooky
    Spooky
    Howza Bruthas,
    I was trying to adjust the brakes on the Lemon Krate and low and behold, the right front bleeder is stripped and oh so round. How does one remove such a bastard?
  2. Muttley
    Muttley
  3. Spooky
    Spooky
    Man I tried. It just continued to be turned into a smoothe surfaced piece. [​IMG]
  4. kritz
    kritz
    from flint, mi
    the crapsman robogrip works pretty good....any chance of getting a small ez out into the hole on the bleeder and backing it out?? if not, dynamite should work.
  5. kyle paul
    kyle paul
    from sac
    buy a new wheel cylinder, or pull it off and lock ot n the vice
  6. fordiac
    fordiac
    from Medina, Oh
    Squeeze as hard as humanly possible on your vise grips. seriously. it should break off before you round it off more.
    otherwise replace the wheel cylinder.
  7. Machinos
    Machinos
    Use a Dremel or something with a cylinder-shaped grinding bit on the end and grind two new sides onto it. Then pound whatever box-end wrench will fit onto it. Depending on how rusty it is it probably will break off first, but I've never actually had a bleeder totally locked up from rust. I ALWAYS use a socket first, and if there's any play in it, I get the next smallest metric size and pound that on.
  8. candyman
    candyman
    I have one this battle with vise grips before as well. I also have done it by cramming a metric box end wrench on it with with a socket. I think the vibration from hitting helps in loosening it as well. A little dab of penetrating oil would help as well I am sure.
  9. Gr8ballsofir
    Gr8ballsofir
  10. Use an "easy-out". Looks sorta like a tapered drill bit. I think Craftsman has them at Sears. They also work for getting broken bolts out. You will need to get a new bleeder after you get it out.
    Clark
  11. Great Balls types faster than I do.
    Clark
  12. Mr 42
    Mr 42
    from Sweden
    Heat it red with a torch, then try to turn before it get coold. Hot wrenching you know ;-)
    Repeat if necessary.
  13. Rocky
    Rocky
    Classified Editor
    Mister 42 nailed it. I've never had any luck removing a busted-off bleeder with an easy-out. And, I'm just dumb enough to have tried about 3 more times after loosing my first ez out when it snapped off in the bleeder..DOH!
    Here's where I'd slide a 5/16ths or a 3/8ths nut over the offending bleeder screw and wire-feed that mutha to the rounded off screw. Just when the red color dies off, pop a socket on the nut and turn the screw out....replace with a new one and use never-sieze on it this time...10 minute operation with almost guaranteed results.
  14. Mart
    Mart
    Was thinking just bang a nut over it, weld it on and replace with a new one, then I foung Rocky had just said the same. It's a sure fire method. EZouts are a complete waste of time.
    Mart.
