HF Pipe Bender - Who's got one?
Discussion in 'The Hokey Ass Message Board' started by Barn Yard Chevy, May 20, 2004.
  1. Barn Yard Chevy
    Barn Yard Chevy
    Who's got one of these things, do you like it & does it work?
  2. I have one and it does work OK. A little slow as you have to pump the jack manually. It also leaves a little dimple where the tube contacts the two rollers. You might be able to avoid this by using an intermediate piece to protect the tube. It does not crush the tube too bad, but it is not a pure bend like a mandrel bend. The tube flattens out a small amount. Depends on how precise you want to get.
    Works great for bending tubing for mini-bike frames.
  3. zman
    zman
    from Garner, NC
    I've got one. I mostly use it for tranny mounts and stuff like that. Is rather slow as was already pointed out. I figure it was worth the $ on sale when I got it but I'm looking at better quality benders now..
  4. A-Bomb
    A-Bomb
    bought one on a friday, took it back saturday. It doesnt like tubing very well. Like the ad says, its a "pipe bender". I am looking around for a deal on a used "tubing bender". Dale
  5. Deyomatic
    Deyomatic
    from CT
    At the risk of sounding like an idiot, what is the difference between "tubing" and "pipe?"
  6. 41ChevyTrucker
    41ChevyTrucker
    [ QUOTE ]
    [/ QUOTE ]
    wall thickness and I think one is always measured inner diameter and the other is always measure outer diameter or at least referenced like that.
    http://www.lowbucktools.com has a decent looking tubing bender
    Read this about what the differences are..... http://www.lowbucktools.com/benderFAQ.html
  7. Barn Yard Chevy
    Barn Yard Chevy
    HHHmmm, I see... Good site there Trucker....
    BYC
  8. OGNC
    OGNC
    You need to chack this place out. It is called Pro-Tools and it is the east-coast version of low-buck tools. Their benders are killer and I know a lot of off-road shops swear by their tube bender. Here is the link...
    www.pro-tools.com
  9. JD SQUARED IN FLORIDA MAKES A DAMNED GOOD ONE -I LIKE MINE.......
  10. Barn Yard Chevy
    Barn Yard Chevy
    Nice Alternatives guys...
    BYC
  11. Morrisman
    Morrisman
    from England
    So, from what I can see in the web pages a pipe bender beands from the middle, like you've pulled it over your knee, and a tube bender appears to bend from one end so the bend is constantly moving along the tube. Other than that, not a lot of difference.
    Other than price. The basic tube bender is fairly cheap, but the dies cost a fortune [​IMG]
  12. [ QUOTE ]
    [/ QUOTE ]
    As noted above, about tubing being measured on the OD and pipe on the ID - not to mention tubing is high quality stuff compared to pipe - the really big difference is the size of the mandrels.
    Making, for the most part, the pipe bender useless for bending most tubing.
    Strength enters into it as well.
    Once you get into roll bar size tubing - 1 5/8 to 1 3/4" - it usually has a wall thickness of .134 (NHRA mandated) and at the least .120 when used for other things - it takes a lot of power to bend the large diameter thicker wall tubing.
    Having said all that, for a while I had one of the HF horizontal pipe benders and made radius rods by using the 1" dies on 7/8" OD tubing.
    Worked fine, the 1" die fit the 7/8" tubing quite well.
    There were no kinks, but - the bend was not too extreme.
    AV8 did a tech article a while back that showcased noted chassis builder Kent Fuller bending curves in dragster chassis tubing using sand and heat.
    SamIyam did much the same and perhaps he'll weigh in here with his methods.
    Which were interesting to say the least . . . but then . . . Sammy boy is always interesting.... [​IMG]
  13. Anyone ever try using one of these cheapo benders on tubing with the tubing filled with sand? Might be worth a try.
  14. stolenmojo
    stolenmojo
    i bought one of the HF versions a few years ago. anyone on here who agrees to pay the shipping - I'll give it to you. that's how much i like and use mine....
  15. Hanible_H20
    Hanible_H20
    This is the bender that you want. I comes with 4 sets of dies, which makes it a steal compared to the other benders.
    https://www.hrsapplications.com/cgi-bin/shoppingcart/cart.cgi?action=link&product=230&uid=3800\
    The price on that one was a little high. I bought mine around 5 years ago between $500 and $600. Mine came from Midwest Tool in Bettendorf, Iowa. I couldn't find a link for them, but there is two phone numbers on the instructional video. (309)-786-0500 and (319)-359-3576. The only problem I've had with this is someone borrowed it who then loaned it to an idiot, who tried to bend some super heavy walled tubing, which in turn bent a roller. If you stay within the ranges given, you'll be fine.
  16. Scrapyard
    Scrapyard
  17. Hanible_H20
    Hanible_H20
    [ QUOTE ]
    What about using one of these? Would this be a better low cost option to then the hydraulic one?
    http://www.northerntool.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=6970&langId=-1&catalogId=4006970&PHOTOS=on&productId=630
    [/ QUOTE ]
    That bender is for small flat and bar stock. Kind of like you'd use for trim and molding. It wouldn't handle tubing. I bought a 180 deg. actual tubing bender of a similar design, but quite bigger. It took two people on a six foot cheater bar to bend the tubing and we were putting our feet on the walls of the shop and pushing to bend it then. The tubing was very thin walled 1".
  18. Scrapyard
    Scrapyard
    [ QUOTE ]
    [/ QUOTE ]
    That's what I was worried about. I'm not exactly a big guy and I'll be working alone 99.9% of the time. I guess I'll keep saving for one of the pro style ones then. I'm planing on building motorcycle frames so I want them do be the best quality I can make them. Thanks for the input.
  19. Hanible_H20
    Hanible_H20
    The pro type benders have to be anchored to the floor, or you'll just drag whatever it is mounted to around the shop. The one I posted a link for earlier has everything you need. It will bend 3/4" od in the one inch die just fine. So with it you have 5 sizes of tubing that you can bend. The Pro Units only come with one die and the additional dies are over $200. The real beauty of it is that it doesn't have to be bolted to anything. You can throw it in the corner when you are done. The Pro units would be good if you were doing some minor production work where you could afford to dedicate some shop space to an Item bolted to the floor.
