Is there high build primer that can be rolled on ? And if there is what kind of roller is used? Thanks
3M made a kit. ****..... it was for spot repairs only. it was only 2in..if u plan on the whole car you'll be there a while..
http://autobodystore.net/Merchant2/merchant.mvc?Screen=PROD&Product_Code=U2202&Category_Code= http://www.google.com/search?q=roll on primer&sourceid=mozilla2&ie=utf-8&oe=utf-8 though I have to ask why you need roll on, like was said for a spot or two sure. There are some good spray cans these days if you just want to spot some stuff.
I have worked for 3M for year and we never made roll on primer. PPG was really pushing it about 6 years ago. They sell the rollers etc at most PPG jobbers. Techs liked the fact you didn't need to mask the car off to prime a spot. Others felt the primer left a "cliff edge" that was hard to feather. If you are into it give it a try. Good Luck
I have some Valspar primer that can be rolled on already, just looking for some hi build stuff. I'm working on a p**** at a time and wanted to prime as I go.
The PPG stuff works good. We use it at school all the time. More orange peel than spray on, but no loss to overspray. We've done some large areas as tests and it worked as well as any.
Just wondering if you can roll it on why couldn't you just do just as good of a job with a brush. With the right brush it might be smoother and easier to sand.
sherwin williams also had one , worked ok squeezey prime, or something to the effect. was like putting on thinned glaze putty, for a full panel, just spray it skull
I've used it in a pinch, and I think it works very well in the proper context. Saves time masking, and no overspray! But you do have to sand it carefully to feather it in.
