I have owned a 32 Roadster since age 17,(46 years now). It has small block Chev. Have also owned several Corvettes since 1977. The models range from 1963 Split Window to 2004 Z06. My question to the Forum is......I have a Sig Erson roller camshaft and have no specs on it. The number on cam is R9000. Other numbers on this cam are...B96 157 08 a sideways 13 and 24M. I've had this cam for a good few years and would like to use it in my new engine for my HotRod. Does anyone please have any info for this cam application? Any help would be appreciated for your new member. Thank you in anticipation, Hans.
Welcome! Now that you've done your intro, you probably should ask the cam question as a new thread in the main section. A lot of people don't check the intros.
G'day from Mile end. Have you tried some of the speed shops like O.G? They may have listings for old cams.
Kia ora from NZ... I'll see if I can dig up my old Sig Erson catalogue and find that part number for you. Agree with George that you should post on the main board, as well. Cheers.
