Hi, I'm a newbie here, this seems like an informative site.
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by Elvira47, Aug 8, 2017.
  1. Elvira47
    Elvira47
    I am looking for info on wiring a chev 3 wire alternator. The main power and voltage sense connections I understand. It's the field wire connection that I am a little miffed about. In most cases this wire is connected to the idiot light from the key acc. terminal. My alternator had a jumper to the field connection. I removed the jumper and the alternator works if you rev it up and excite the field. What is the best way to connect this wire?
    thanks
    SAM3 Customs likes this.
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    Wrong place for questions but the right place for introductions.
    lothiandon1940 likes this.
  3. LAROKE
    LAROKE
    When I was re-wiring my '55 Chevy pickup a few years ago (12 volt conversion), I found a diagram in Petersons "Basic Ignition and Electrical Systems", a Hot Rod Magazine Technical Library book published in 1971 which I bought back when I had pimples all over my face (well, more pimples anyway).
    wraymen, Elvira47 and lothiandon1940 like this.
  4. 28 Ford PU
    28 Ford PU
    from Upstate NY
    You'll need to find a site that discusses traditional rods and customs.
  5. Elvira47
    Elvira47
    okay, where should I ask questions
  6. HOTRODPRIMER
    HOTRODPRIMER
    This is the introduction section,Welcme to the Hamb.
    Post your question HERE. HRP
