Projects "Hidden Agenda" Turbo Model A coupe rebuild
Discussion in 'The Hokey Ass Message Board' started by 100mph WHEELSPINNER, Mar 21, 2009.
  1. Tim_with_a_T
    Tim_with_a_T
    LS7 are a great low-cost late model block option though. I recently discovered those.
  2. loudbang
    AUUUGGGH he has gone over to the DARK SIDE :eek:
  3. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    Motor and trans are one unit! Special thanks to all the guys at Bowler transmissions for all the help! Fitting the hood, then the motor and trans are ready to be put in.
  4. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    Still working on the hood!
  5. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    Tim_with_a_T and Baumi like this.
  6. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    001 A001 MAIN COUPE BODY.JPG 002 A001 MAIN COUPE BODY.JPG 004 A001 MAIN COUPE BODY.JPG 005 A001 MAIN COUPE BODY.JPG 006 A A001 MAIN COUPE BODY.JPG 006 A001 MAIN COUPE BODY(1).JPG 007 A001 MAIN COUPE WITH ROLL PAN.JPG Back working on the coupe. Sure cant wait to have her back on the road. While putting the coupe back together I have been using a 3d scanner that I use for work to get the coupe into my computer to design a rear roll pan and the turbo ducting from the 32 cowl vent. I am uploading some soldworks screen shots to show where Im at in the process.
  7. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    Got the body channeled and the grill raised for the best fit I could for the hood in the future. Body and engine scanned, time to start putting the turbo parts back on. Its been 14 years since I started this post. Hopefully I will finally get this thing together the way I originally intended. Its no ones fault but my own. Being a Hotroder is not a hobby its a lifestyle.
    Tim, TexasHardcore and jim32 like this.
  8. Wow, that's luxurious. It'd be cool if you started a separate thread for your scanning and SolidWorks stuff. Did you scan the body?
  9. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    Yes the body is scanned. inside and out. scanned the engine and trans separate and pieced it all together in solidworks.
    Tman, Tim, CoolHand and 1 other person like this.
  10. Tim
    Tim
    from KCMO
  11. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    I took your advice and started a thread. Thanks
  12. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    Got the sbc back in with the new magnum t56. The new t56 had a wider transmission mount boss compared to the viper t-56 that was in the car before. Next step is to put all the turbo stuff back on. KIMG0615.JPG
    Tim and Malcolm like this.
  13. flamedabone
    flamedabone
    You are gonna need to throw a set of sticky tires in the trunk for whenever you get to where you are goin...
    -Abone.
    Tim likes this.
  14. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    I'm working on that. Plan on having some slicks.
