Hide my emergency hand brake
Discussion in 'The Hokey Ass Message Board' started by Tedders, Apr 22, 2013.
  1. Tedders
    Tedders
    Have a ugly modern hand brake inbetween the seats any one out there with a stellar way to hide it?
  2. 49ratfink
    49ratfink
    I'd be more concerned with the ugly steering column.
  3. hotrod40coupe
    hotrod40coupe
    I would think those seats would draw the attention away from the emergency hand brake.
  4. Mount the mechanism in a recessed box in the bulkhead between the seats, with a cover. Use the cover as the lever.
    Camouflage paint. And put some on the steering column too.
  5. Tedders
    Tedders
    This site can be so amazing the support and new friends, been on here long enough to know that thankfully.
    I'm just starting out on the car and yes the colum and the seats will go but there is no need for the comments, what if I was new? Ad this would be my first introduction to the site?
    Like I said some of you guys are the best truly into what it is and some of you are just ***holes.
    If anyone has some creative ways to hide the P brake love to hear it and see it
  6. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    . . . just get an older e-brake handle. They're a plenty, easy to adapt to work with just about anything, and you wont have to hide it cause it'll look right.
  7. Tedders
    Tedders
    Thanks Rick appreciate it
  8. Olderchild
    Olderchild
    from Ohio
    what were you building a car or b*** boat?
  9. Tedders
    Tedders
    Thanks zombie
  10. I can be helpful and smart***ed too...lol.
  11. Tedders
    Tedders
    Well as long as helpful is first its all good
  12. Tedders
    Tedders
  13. tb33anda3rd
    tb33anda3rd
    build a console over it.
  14. Checkerwagon
    Checkerwagon
    "I'm just starting out on the car and yes the colum and the seats will go but there is no need for the comments, what if I was new?
    Ad this would be my first introduction to the site?"
    Well, yes, it would be.
    As to positive suggestions;
    Consider moving the brake handle to a different location.
    Re-purpose an E-brake lever from an older car.
    Build a E-brake lever, make the cable brake release from a motorcycle hand lever.
    All the best,
    Dale
    Cleveland OH
  15. Now that'll work. Thanks for that. Saved for future reference.
    Btw...Don't get too bent outa shape at the smart***ed remarks. There's often some truth in there somewhere...in spite of the ***holinessisms. :)
  16. sawbuck
    sawbuck
    from 06492 ct
    cover it with a paper bag .....a brown one...
  17. shinysideup
    shinysideup
    from ruskin, fl
    Was this tissue dispenser covering it before?
  18. Tedders
    Tedders
    lol yeah and you don't know the worst part yet the top is....chrome
  19. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Console or such would be easy, steal one out of an older car. I have a pretty modern one Im going to install. I keep looking at it thinking about cutting off all the rubber and having some bare metal to play with.
  20. captain scarlet
    captain scarlet
    from Detroit
    Don't forget that it is an EMERGENCY brake not just for parking.
    If you ever need it in a brake failure then hidden could be a problem. Just look for an older style or a common place to tuck it is across the front of the seats.
    Basically within reach.
  21. 49ratfink
    49ratfink
    yes, but we are ***holes with cool steering columns.
  22. why not an under dash pull type t-handle style, like out of a shoebox ford?
  23. fossilfish
    fossilfish
    from Texas
    You can buy a leather cover that covers everything but the padded portion of the handle. It covers the mechanism. If you get a cover it slip over the handle and should go under the carpet. You can have one made to fit and it will look better. That is a handle for a vega and a number of other gm cars.
  24. Devin
    Devin
    from Napa, CA
    Lokar makes a nice cover for their e-brake handles, I'm not sure if they will fit the dimensions of your handle though. Kinda expensive but most likely cheaper than what an upholsterer would charge.
  25. Tedders
    Tedders
  26. blue 49
    blue 49
    from Iowa
    Mine's usually hidden by can coolers, maps or fast food wrappers.
    Blue
  27. GassersGarage
    GassersGarage
    Lokar makes a trans mounted lever which I had on my '32. My '31 Had a lever under the dash but still accessible by the driver. In either case, if the hydraulic brake failed, I could still use the emergency brake. The E-Stop appears to be a parking brake only.
