Projects high-boy rear axle
Discussion in 'The Hokey Ass Message Board' started by Shane Hoffman, Feb 19, 2016.
  1. Shane Hoffman
    Shane Hoffman
    I am starting to build a 28-29 Ford Model A High-boy coupe with narrow steel rims. Wanting the car to look more traditional I will have the rear end attached with a leaf spring style set up. I am planning using a chevy rear axle and front rotors. What cars or truck axles should I look for?
  2. von Dyck
    von Dyck
    A Chevy-GMC 1/2 ton from '55 to '59 looks good. Jack Dooney of Mesa, AZ used one in his Kookie tribute T-Bucket. You'll have to go back into the late '80s Hot Rod Magazine archives to see the feature article. It looked good!
  3. Nailhead Jason
    Nailhead Jason
    A first gen Camaro rear would be about the right width for that. its the same basic size as a mustang 9 inch and is much easier to find.
  4. timwhit
    timwhit
    Let me see if I understand. You want a traditional rearend, buggy spring ? or parallel leafs? Chevy front axle? with disc brake rotors? Lets clarify this much and go from there. Tim BTW...welcome to the Hamb.
    RICH B likes this.
  5. Shane Hoffman
    Shane Hoffman
    Will be using ford model a straight front axle, 37-40 ford spindles, and split wish bones. Speedway motors disc brake conversion on the front. On the rear would like to run buggy spring style with 36-39 ford style radius rods. just didn't know if I could use a s-10 rear axle or maybe something out a 78-87 El Camino .
  6. thirtytwo
    thirtytwo
    On hotrods with welded suspension tabs, ect I like to do something with a 3rd member or banjo , it makes the " mechanical" piece easy to replace and all your brackets stay with the car..
    9" is really the way to go for ease and parts availability , the right widths can still be bought used fairly reasonable... It does take searching though..
    I got a few 55-64 Chevy rears for free and used those but 100.00 per wheel bearing it became more expensive than the stronger 9"
  7. Larry Pearsall
    Larry Pearsall
    Everyone thinks a 9 inch rear is a must.. 8 inch rears can also be found easy , sometimes in narrower width an will handle most horsepower under 400 horse. Usually less money than 9 inch and use as heavy of axles.
    Andy, i.rant and lothiandon1940 like this.
  8. thirtytwo
    thirtytwo
    It all depends on location on that one.. I have heard guys say they are stacked like cord wood in their area and guys that tell me Impossible to find in others , 8" I believe had a limited run in mustangs and Granada , m-2, where
    9"ers were used from 1957 in many different cars trucks into late 70s , not to mention the aftermarket industry caters almost exclusively to them ... Lots of production 9" are in that 58-61" area which is good for a fender less hotrod
    I agree though ...if you find a good 8" under 150.00 I'd use that... Unless you find a 9" for the same price
  9. Bader2
    Bader2
    Traditional,Chevy rear axle and rotors? Yeah,right.
  10. S10 rear and front rotors? Absolutely NOTHING traditional about that.
  11. Kerry
    Kerry
    For me it was important to put a package together that functions the way I want, and looks good/right in the process. I run front discs on my 31 Pontiac. It run's 115 in the quarter so I like the stopping power. Most folks look at the hemi and never mention the disk brakes. That said, don't let the formula guys put you in a box. Read a bunch of old Hot Rod mags and you'll see a bit of everything. It's your car, build it your way, but do give thought to how it all comes together.
    JMO but a rearend with a removable third member presents a nicer look, and is easier to work on as has been mentioned. Ford 8 and 9 inch rears can be built cheaper than most others that fall in this category.
    Hitchhiker likes this.
  12. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    How about a roundback 9-incher with a quick change center section grafted on for "the look" with the functionality and practicality of the niner.
