Projects High Desert Hop Up
Discussion in 'Traditional Hot Rods' started by Felipe Toltecatl, Jul 21, 2015.
  1. I hope I'm not starting this thread too early. I work very slowly! The goal is a 40's style Model T Touring hop up. So here's what I'm starting out with.... A solid '30 Model A frame scored from a friend in El Paso, a '47 Ford front axle dropped 4" and converted to a spring over set up with a Posies spring and a set of new wishbones from Speedway. The rear end is a rebuilt '40 Ford with an open drive conversion also from Speedway and an original Model A rear spring. She has rebuilt '47 Ford brakes in front and '40 Ford brakes out back.
  2. As far as motorvation only a flathead will do. It's a 59AB with an Offy dual carb intake and two Holley 94's. Transmission is a T5 out of an S10 (that's where I cheated and also what will keep this out of the really cool traditional events like TROG and the Hot Rod Hill Climb in CO). Oh well.
  3. This is the look I'm loosely shooting for.
  4. The body is an original '27 T touring scored here on the HAMB last year.
  5. F1 shock mounts modified to fit the Model A frame. 20150713_175210.jpg 20150713_175210.jpg 20150711_140403.jpg
  6. Texas Webb
    Texas Webb
    Looks like a good build plan.
    Felipe Toltecatl likes this.
  7. Wheels are '30 Model A. Just got her on all fours this week. 20150714_133817.jpg 20150714_133844.jpg 20150714_133909.jpg 20150714_133804.jpg
    Dedsoto and LOU WELLS like this.
  8. Jalopy Joker
    Jalopy Joker
    Cool - doing good
  9. Next goal is to get the motor and trans installed before I loose momentum!
  10. 3wLarry
    3wLarry
    from Owasso, Ok
    looks like a fun build...I'm in
  11. Randy Radford
    Randy Radford
  12. New water pumps go on this weekend and hopefully I'll get the motor cleaned and painted too.
  13. So yeah I work pretty slowly and it's been hot as hell the last couple days in southern New Mexico but I did manage to make a lil progress. The flatty is just about ready for the new water pumps and a fresh coat of high temp racing green engine paint. 20150727_180513.jpg 20150727_180513.jpg 20150727_180513.jpg
  14. One more scrubbing and I'll start spraying.
  15. czuch az
    czuch az
    Thats gonna be nice.
  16. I installed the water pumps and gave her the 20150728_183122.jpg first coat of high temp racing green engine paint!
  17. I LUV this shade of green!
  18. 20160229_185907.jpg Motor and transmission are in with the help of an 8" drop crossmember from Speedway. They're sitting pretty at 3°.
  19. 20160309_183304.jpg THIS is the 8" drop crossmember. That last pic was of a 4" that didn't work.
  20. 20160411_183210.jpg The day the body went on.
  21. 20160324_185100.jpg Chopped the windshield posts.
  22. 20160421_182408-1.jpg Windshield installed.
    jerseyboy likes this.
