Customs High idle after acceleration
Discussion in 'The Hokey Ass Message Board' started by cluxford, Sep 18, 2023.
  1. cluxford
    cluxford
    from Australia
    BBC
    Idle is circa 970-1000 RPM in park
    Drops to around 810-820 in drive
    Cruise RPM ranges between 1700 - 2100 and WOT I only ever take it up to 5000
    After acceleration in drive, but with my foot off the gas pedal, rpm slowly drops to around 1300 and rarely goes below.
    I'm fouling plugs in 10 mins. Badly fouled.
    Carb is an 4500 style Quickfuel
    Fuel pressure 3 psi
    floats are only 1/3rd up on the sight bowl
    idle screws only 1/2 a turn out
    I have reduced the transition slot and even lowered the jet sizes by 6 sizes
    I have also triple checked the pump shot
    I've replaced return springs.
    Somehow someway the carb keeps feeding fuel to the engine when my foot is off the gas.
    Any thoughts ?
  2. SS327
    SS327
    How big is the carb? Sounds like it is way too rich. What jets, power valve?
  3. cluxford
    cluxford
    from Australia
    It's an 1150 but the engine has had a lot of work done to it including higher compression and bigger cam. Something has changed as it ran fine up until recently
  4. MAD MIKE
    MAD MIKE
    from 94577
  5. cluxford
    cluxford
    from Australia
    OK think I have solved it...fired it up and watched carb closely under load then idle. Rear secondary pump shot was leaking fuel between the nozzle and the screw. Go to tighten it and guess what...stripped. I suspect this has been ******* fuel into the carb. Out to get a helical kit tomorrow. Probably need to resent all my changes once I fix that
    loudbang and SS327 like this.
