Hot Rods HIgh temp paint on brake drums
Discussion in 'The Hokey Ass Message Board' started by ThosD, Feb 20, 2022.
  1. ThosD
    ThosD
    I bought some POR15 high temp aerosol paint (good up to 1200 *F) for my new brake drums that had been kiss turned to insure roundness. In reading the instructions I see that the paint does not reach full cure until the painted parts are baked for at least 2 hours at 400*F or higher.
    Bake the drums in the kitchen oven? Not when the little woman with a big voice is home.
    I am concerned that the high temp cure may distort the new drums. Has anyone used this paint without the oven cure?
  2. Have not done brake drums, but have had exhaust manifolds in the oven at 350 with no warping. She who must be obeyed was at work at the time...
  3. goldmountain
    goldmountain
    Why are we so afraid of little women?
    Deuces, kadillackid and caseywheels like this.
  4. goldmountain
    goldmountain
    On another note, I had the rear brake drums on my car powder coated. Later, it looks like one of them was removed from the car by heating the center of the drum with a torch which damaged the powder coat. What gets me, is that I'm the only one in my garage and I didn't do that. Sneaky gremlins.
  5. What’s wrong with just regular high heat black paint ?
    Tommy
    Deuces, 1oldtimer, egads and 2 others like this.
  6. ThosD
    ThosD
    What is the temperature rating for regular high heat black paint? The paints with higher temp ratings require heated curing. The POR15 I have is rated to work up to 1200*F. Paint that cures through use on drums or calipers is rated at 900*F. I already own the 1200*F paint. But, I may just buy some 900*F rattle can paint and be done. I don't want to suffer through peeling paint because I did not properly cure it.
  7. millersgarage
    millersgarage
    it will stink up the oven, don't do it in one you cook food in.
    ClarkH, WalkerMD, swade41 and 3 others like this.
  8. kevinrevin
    kevinrevin
    from East Texas
    How would 400 in an oven warp the drums, when much higher braking temps on the car don't?
  9. indyjps
    indyjps
    Shoot the paint, let it dry well, then put them in your gas grill. Burn off your gas grill on high heat after you're done.
    Bandit Billy and Deuces like this.
  10. I bake parts in the oven and wash em in the dish washer
    You’re good
    X-cpe and loudbang like this.
  11. oldiron 440
    oldiron 440
    Just make sure you don't get any paint on the working surface of the drums....
  12. krylon32
    krylon32
    from Nebraska
    Don't know about POR but I've powder coated quite a few drums with no problems.
  13. HOTRODPRIMER
    HOTRODPRIMER
    I always use regular spray paint, never had a problem with paint pealing,.
    I can ***ure you if you use the oven in the house you will be buying the wife a new one, please don't ask me how I know! :mad: HRP
  14. VHT. Flame proof is supposed to be good from 1300-2000 degrees Fahrenheit .
    Sounds pretty high to me .
    Tommy
    Budget36 and Deuces like this.
  15. SpeedyAtkins
    SpeedyAtkins
    You can pick up a cheap toaster oven at almost any second hand shop to bake parts in.
    Deuces and David Gersic like this.
  16. H380
    H380
    from Louisiana
    I have regular rust-oleum gloss black on my DD pickup back drums. The first and only paint job has been there 25 years now. But I don't have road salt.
    46international and swade41 like this.
  17. blue 49
    blue 49
    from Iowa
    I use engine enamel. Dries fast and has a plenty high enough temp rating, unless you're going road racing and plan to really heat your brakes.
    Gary
    Deuces likes this.
  18. Paint 'em and take 'em over to @anthony myrick 's house... he gets by with a lot of **** us mere mortals don't!
    MMM1693, loudbang, pprather and 3 others like this.
  19. gene-koning
    gene-koning
    I've only ever used regular paint on brake drums, never had a problem, but I'm not road racing either.
    rusty valley and Deuces like this.
  20. Rebuilding a q-jet in the kitchen.
    Wife thinks it’s funny
  21. I used the regular Platikote gloss black engine enamel with ceramic on the drums of the '41 (after blasting them) and they still look great over 2 years later.
    Desoto291Hemi and Deuces like this.
  22. So do you think she's laughing AT you or WITH you?? Not trying to stir up trouble, just wondering...
    Deuces likes this.
  23. Budget36
    Budget36
    Might be tough to find one deep enough for a brake drum though.
    SpeedyAtkins likes this.
  24. Probably a little of both.
    She came home one evening and thought I was cooking dinner. I was boiling a carburetor
  25. 55blacktie
    55blacktie
    Some aren't so little.
  26. 55blacktie
    55blacktie
    I used VHT caliper paint. I did put them in the oven, but at a lower temp. Putting the painted drums in the oven to cure is not necessary, as the paint will cure from brake heat. Either the smell from curing in the oven wasn't that bad, or my wife was out of town.
    Keep in mind, when it comes to wives, "The pen is mightier than the sword."
  27. jimmy six
    jimmy six
    All carb parts go thru a wash/rinse in the dishwasher with Finish and 1/2 cup of vinegar after a little external brushing on the hottest cycle. You will like how they come out.
    Years ago I made a 3’x2’x2’ wooden box with a hinged lid and 2 250 watt heat lamps. My son has it now. You really needed to watch the heat.
    anthony myrick likes this.
  28. jaracer
    jaracer
    Don't wait too long to get them heat cured. I painted a set of headers with paint that needed high temp to cure. I didn't get around to putting them on the car for maybe 4 years. When I first started the engine and got it up to temp, the paint just fell off the headers. Pulled them and repainted with the same paint but put them back on and got them up to temp right away. They look good 2 years later.
  29. swade41
    swade41
    from Buffalo,NY
    I paint my drums with regular old Rustoleum and never had an issue of it burning off, of course I don't ride my brakes or go scta racing, just normal city driving.
    46international and Crazy Steve like this.
  30. 55blacktie
    55blacktie
    Did you put those headers on a newly rebuilt engine?
