High torque mini starter
Discussion in 'The Hokey Ass Message Board' started by desotoman53, Jun 8, 2019.
  1. desotoman53
    desotoman53
    from Conroe
    I’m installing a mini starter when I turn the key the starter spins but doesn’t engage. I’ve replace the solenoid and just can’t figure out what I have wrong.
  2. Blue One
    Blue One
    from Alberta
    Most high torque mini starters have their own built in solenoid and you have replaced a new solenoid?
    Did you bother to look at the instructions and measure the distance from the ring gear to the mounting face where the starter bolts on?
    (That’s the engagement distance)
    Last question is did you get the right starter for your application?
    These things aren’t that hard to make work.
  3. The other question is did you connect the solenoid on the mini starter up correctly so it actually gets power?
  4. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Bench test it to see if the Bendix is activating.
    VANDENPLAS and Pist-n-Broke like this.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Who's (manufacture) starter and what engine is it for?
  6. desotoman53
    desotoman53
    from Conroe
    I’ve been messing with it if I turn key it spins. If I jump a wire from bat on starter it engages. It won’t work with the key though.
  7. desotoman53
    desotoman53
    from Conroe
    Summit high torque mini starter. In line six Chevy 250 motor.
  8. squirrel
    maybe you could post a couple pictures of how it's wired? or a more thorough description?
  9. desotoman53
    desotoman53
    from Conroe
  10. Blue One
    Blue One
    from Alberta
    Sounds like a wiring problem :confused:
    You didn’t answer the solenoid question.
  11. desotoman53
    desotoman53
    from Conroe
    Purp solenoid I have bat to fuse and bat to alt on the other post.
  12. desotoman53
    desotoman53
    from Conroe
    I tried a jumper from solenoid to the top post but didn’t work.
  13. desotoman53
    desotoman53
    from Conroe
    The solenoid is new and works when engaging the motor. Just not when I turn the key. I’ve put a jump wire from that terminal and touched every port on my ignition and nothing.
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Put the wire onto screw above instead.
  15. desotoman53
    desotoman53
    from Conroe
    This is the first time I’m trying it. Just still putting it back together.
  16. squirrel
    yup, the little screw terminal is where the little wire from the key switch connects.
  17. desotoman53
    desotoman53
    from Conroe
    I didn’t hook up a safety switch.
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Summit is good about having online instructions. Be aware the photo I posted does not match what you have. Did you put motor wire (motor to solenoid) onto correct terminal on the replacement solenoid?
  19. 57 Fargo
    57 Fargo
    These guys got you covered with the above
  20. Hook up your ignition key wire to the small screw post
    Move your battery wire and alt wire over to the other post.
    Safety switch?
    Like a neutral safety or clutch switch?
    What are you running as far as trans and shifter etc
    Lots of diagrams on line etc.
  21. squirrel
    nope, they are on the correct terminal already...
    57 Fargo likes this.
  22. desotoman53
    desotoman53
    from Conroe
    Yep thanks I did that as soon as the safety switch was mentioned. Thanks for all the help
  23. desotoman53
    desotoman53
    from Conroe
    Just need those extra eyes now and again. Once again thanks for all the help.
    VANDENPLAS likes this.
  24. Blue One
    Blue One
    from Alberta
    So it’s working now and it was a wiring problem :cool:
  25. Think I need gl***es
    Your right
    I’m not looking hard enough.
  26. goldmountain
    goldmountain
    I think your purple wire should go to that small screw between the two big posts.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Hurry!, if you leave this thread now you mite make the next thread on time. When there, be sure to see everyone that's already there. :D
  28. Mike Colemire
    Mike Colemire
    Purple wire in the wrong place.
  29. if you are using point/condenser/ballast things wire different to the ign switch
