Highway wheel hop
Discussion in 'The Hokey Ass Message Board' started by Posterchild37, Jun 7, 2007.
  1. Posterchild37
    Posterchild37
    from Michigan
    Ar about 65 mph my wheels get the basketball effect bouncing up and down so i have to slow down other than that the car is great
    I WANT TO GO FASTER what will solve this problem?
    Shocks?
  2. jetmek
    jetmek
    sure couldnt hurt. detroit uses em for a reason
  3. speedtool
    speedtool
    You did balance your tires after mounting, didn't you?
  4. xderelict
    xderelict
    Shocks will fix that.Your rebound off the spring is making your wheels hop,The dampening action will smooth them right out.Could we see some other angle on that front end set up?Suicide front end may be understating it.
  5. tootallrodder
    tootallrodder
    Absolutley add shocks. If you don't have them on the rear you need to add them there also.
    Another blaring thing I see on you front end shot is the lack of solid mounting point for the flexible brake lines. The brake line will fail in shor order unless you add the secure mount. It looks like you will need to get longer brake lines in order to reach the frame rails where the hose needs to ne mounted.
    Good luck with your ride
  6. Posterchild37
    Posterchild37
    from Michigan
  7. Ornery37
    Ornery37
    from Texas
    I was told, if they are bias tires with tubes run a lower air pressure, bout 18-20 psi. Alignment check, also.
    I have shocks, drum brakes, and bias w/tubes and between 66-69 mph they bounce but any thing above or below they are great. I usually run 70mph with no issue.
  8. I have a similar issue at the moment, my front tires are not true (have a high spot, or flat spot) and need to be cut true. Jack up the front end and spin the front wheels by hand. Look carefully from the side and if you see it go up, down, up, down then that is your problem and you need to have the tires trued. And it goes without saying that you need front shocks in good working order.
  9. pasadenahotrod
    pasadenahotrod
    from Texas
    Shocks and a little radiator black or a grille to cover up that advertising logo will fix you up real nice.
  10. Saoutlaws_Gotti
    Saoutlaws_Gotti
    yeah had the same problem with my A Sedan and shocks solved the whole problem and made it ride Oh So Much Better
  11. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Actually, I'm amazed that it takes 65 mph to produce wheel hop. Must have some mighty smooth roads up there in Mich.
  12. dana barlow
    dana barlow
    from Miami Fla.
    Shocks #1
    balance and ture tires
    fix brake lines as stated above
    alinement//can't tell from photo but is your ackermen at lest close,most front steer are very badly done and need fixing.
    Can't tell from photo ,but is spring U clamp mount Strong?
    Panhard bar on front will help other wiggels too
  13. DE SOTO
    DE SOTO
    With the front end stretched way out there, 4ft long drag link, long shackles on a 3leaf trailer spring & un~safe looking spring pearch.
    It may be hard to make this front end safe & not bounce ... shocks WILL help, actually cant believe they werent installed in the build.
    Check tires for true, wheels for bent, toe in, balanced tires, and for gods sake... mount the brake lines.
    My opinion is that front end set up is SCAAAREYYYY !!
    While were here, can I ask why do guys push the front end so far out ?? Whats the point or purpose ???
  14. touchdowntodd
    touchdowntodd
    DESOTO always asks the right questions.... hahaha
  15. lewislynn
    lewislynn
    No offense but for your own safety that front end doesn't look safe at any speed.
  16. I had a Blazer that did that in the rear. Seems someone lowered the rear by removing a few leaves from the spring pack. I put a "full" spring pack in it and it went away. Your spring pack looks a little "light". Keep this in mind in case shocks don't fix all the bounce
  17. hemi coupe
    hemi coupe
    from so-cal
    What Groucho said!! You need some springs in there.. The distance from
    the main leaf to to the second leaf is to wide. Add some leafs and some shocks and it will probably help alot.
    Jimmy White
