Does any one have any info on this pump and can you use this pump to fuel a carb instead of an injection unit.thanks
It's a positive displacement pump. It will overcome the needel valve and flood the motor. You would need a byp*** set to open at just over? or under? right at? your needle and a line for the excess back to the tank. Or better than that a return fron the float bowl at the fuel level you want and throw away the needle and seat and the float. Floatless carb. Very racy.
