Hilborn Injection
Discussion in 'The Hokey Ass Message Board' started by injunnuity, Mar 29, 2006.
  1. injunnuity
    injunnuity
    from Wisconsin
    Hope this is not a stupied question But Just was wondering what needs to be done to switch from gasoline to Alcohol on old Hilborn injection unit is it just the injectors or a different Pill or nothing at all ? :eek:
  2. Bugman
    Bugman
    Injectors and pill, possibly the fuel pump. Remember to drain the system after each use because the alcohol will attack the aluminum over time.
  3. rodknocker
    rodknocker
    hellzapopin just converted his try to get ahold of him for some questions.saw his thread last week
  4. Roothawg
    Roothawg
    Bigger nozzles and open up the barrel valve to let more fuel in at idle, and change your return pill. That's it.
  5. hog mtn dave
    hog mtn dave
    Look at Hilborn's website. There's some useful info there. You can call them for tech help. Ask for Vern.
    www.hilborninjection.com
    My car is running and sounds great, but it hasn't been down the track yet. I know just enough about this stuff to realize I'm in no postion to offer any advice. Good luck.
  6. Gemini EFI
    Gemini EFI
    Depends on what pump you're running. Change nozzles and pill. Reset barrel valve. You may have to change pump. Alcohol takes twice as much fuel as gasoline. You should be around 195 to 205 degrees at end of a run to make most power.
    Gemini EFI
