Technical Hilborn pump HELP!
Discussion in 'Traditional Hot Rods' started by VA HAMB, Feb 5, 2021.
  1. VA HAMB
    VA HAMB
    I'm trying to get this Hilborn system set up on my restoration. The original builder just had an old water gate valve for a fuel shut off. I'd like it a little better for safety. It was all in boxes when I bought it so I'm not exactly how this sets up. I've Googled the **** out of it but what I'm mostly seeing are schematics for a pump with one inlet and one outlette. Mine has an in an out and two others that I ***ume are the byp*** ports? Am I correct? do these need valves like a High and Low Speed??? I'm lost. I need to get a shutoff valve and would like to get the correct one. Maybe even fine a good vintage one that'll work. HELP PLEASE!
    loudbang, AHotRod, mad mikey and 2 others like this.
  2. 1934coupe
    1934coupe
    VA try Mike from Alky Digger he's in Tenn. he helped me out BIG TIME with my Hilborn on my MG. I may have a old shut off valve that was used on the MG but opted on one from Mike that worked out better. I'll look for it, if I find it you can have it just pay postage.
    Pat
  3. jaracer
    jaracer
    Back in my sprint car days with alcohol, I ran a -8 line to the pump inlet. It had a filter like the ones you used to see on filling station gas pumps. NAPA used to sell the filter. I also had my fuel shut-off valve in this line. We used to use some kind of military valve that was a 1/4 turn. Speedway Motors used to have them. Now they have a different but good ***ortment of shut-off valves.
    On the pump outlet, a -6 line was plumbed as the main by-p***. This had the by-p*** valve and main jet. Another line was plumbed to the barrel valve, probably a -6, but I don't remember. I didn't use any other by-p*** setups and the other outlet ports on the pump were plugged.
    Hilborn also recommended that the shut-off valve be plumbed between the pump and barrel valve. That way you didn't shut fuel up to the pump and it wasn't run dry. It never caused a problem for me to have it in the supply line, but I see their point.
    Hope that helps.
    loudbang, mad mikey and VA HAMB like this.
  4. jimmy six
    jimmy six
    I’ve got pumps like yours. On the street you don’t need any high speeds at least I didn’t use any. 1 in and 1 out and a tee in the out line for the byp***. I never screwed the byp*** into the pump like many do. Learned early that engine vibration on a byp*** was not your friend. You can make a small tank with Holley float bowls on the end and use it for your byp*** return. And fill the small tank from an electric or stock mechanical pump from your engine. It’s been done thousands of times on the street. I had my shut off attached directly to the barrel valve for ez starting. Used a Controls Cable cable not a old choke cable.
    A guy with a 55 Chevrolet comes to our Saturday morning gathering and been running his on the street for years. Good luck
  5. VA HAMB
    VA HAMB
    Awesome thankS!
  6. VA HAMB
    VA HAMB
    Thanks, Not running this on the street. It's a vintage drag truck restoration. I'll be running alcohol
    loudbang, adam401 and jimmy six like this.
  7. VA HAMB
    VA HAMB
  8. 19Eddy30
    19Eddy30
    from VA
    Kinsler fuel injections has a Great tech / catalog combined in one book full of Information , it's roughly over 250 pages,
    Mechanical fuel injection appears to be complicated but once you learn how it works keep notes it's fairly easy to adjust and set up
    neverdun, loudbang, jimmy six and 2 others like this.
  9. 1934coupe
    1934coupe
    VA here is the valve, it has a filter attached to it. It is a little stiff because it has been on the shelf over 50 yrs. It takes #10 or 12 AN fittings. Is that your truck? A friend and compe***or has one almost like it, it is called "Bad News" and we ran against it at Dover dragstrip in the 60's. Send me your address and I will ship this out. I would still get ahold of Mike at Alky Digger.
    Pat
  10. VA HAMB
    VA HAMB
    Thanks Pat. Message sent....I think
  11. Fitnessguy
    Fitnessguy
    Love it!! What’s the current state of the truck like? Love to see pics of it now. I’d be tempted to reach out to the Rex Rod guys in Texas. He’s building vintage motors all the time and plays with all the old stuff. Super nice guys so I’m sure they’d be able to help or point you in the right direction
  12. On any of the mechanical pumps, the fuel shut off needs to byp*** the fuel back to the tank or to the pump inlet if there is no spring loaded byp*** on the pump such as a Hilborn. I've never seen an Enderle with one. If you don't, when you close the shutoff, the pump pressure will spike and shear the pump drive or wipe out the pump clearances in a heart beat.
    loudbang and 19Eddy30 like this.
  13. 19Eddy30
    19Eddy30
    from VA
    F4777BF1-A8A5-40B4-8C5D-6FF5BFD81211.png 2121DD5E-9291-4D3F-95D4-2B3B5B3B4D8C.png 7482F362-7FCD-4D46-9F50-A5C347E96F03.png
    There is Many ways plum & use puppet
    To teller yr need & experiment.
    loudbang, ottoman and VA HAMB like this.
  14. VA HAMB
    VA HAMB
    Search Official B Altered Restoration. I have a thread on here. Can't figure how to post thread on my phone. I'm actually out here painting it now.
    Sent from my motorola razr (2020) using The H.A.M.B. mobile app
    loudbang and Fitnessguy like this.
  15. earlyv8ford
    earlyv8ford
    I would like to convert an old 60s fuel injection set up on my 33 3w but want it reliable as well!
    rod1 and loudbang like this.
  16. Roothawg
    Roothawg
    Don’t worry about all the extra stuff like a high speed byp***. You can plumb that stuff in later. Forget everything you know about carbs. Think about tractors or hydraulic systems.
    The pump is fed from the bottom of the tank and the amount of fuel returning to the tank determines your amount of fuel (pill size or jets). It’s just a pressure system. I’m sure there are guys in here that can help you get it figured out. They are really easier time than carbs.
    neverdun and loudbang like this.
  17. loudbang
