Projects Hillman Husky Gasser
Discussion in 'The Hokey Ass Message Board' started by AldeanFan, Nov 4, 2018.
  1. Have you seen this?
    This car was built in the 60's and restored by a family member after a long journey to find it.
  2. AldeanFan
    AldeanFan
    Last night we set the engine in place.
    We have to move a brake line away from the header but everything else appears to have good clearance.
  3. AldeanFan
    AldeanFan
    Last night I made a hole.
  4. 55 Ford Gasser
    55 Ford Gasser
    Funny thing, I was at an estate sale and there was a Hillman Husky for sale. It looked to be in real good condition and I was already thinking about a frame for it. I was all excited and before I could get a chance to see the price, I woke up. Lol. Seriously, that is what I dreamed last night. I hate those kind of dreams. I'll be thinking about it all day and probably start going to more Estate Sales.
  5. AldeanFan
    AldeanFan
    Tank mounted, plumbing and wiring next.
    That bumper is from a Crosley.
  6. This is looking awesome guys
  7. OLSKOOL57
    OLSKOOL57
    “ROLLING ROCK “.................Little Green Meanies. Remember them well !!!!
  8. AldeanFan
    AldeanFan
    Headlights, need ideas.
    So we have no headlight hardware or anything at all besides two big holes.
    I need to figure out something for headlights that doesn’t look silly and doesn’t cost much. It’s a track only car so lights would be for night racing.
    Any suggestions?
  9. rudestude
    rudestude
    Well I can kind of show you what the original one's look like.
    I had a 57 Hillman Husky project that I sold a couple years ago and strangely I kept the headlight bucket ***emblies.....
    But I used them in building some headlight buckets for my 50 Chevrolet Bel-Air HT. They worked out great it will allow me to remove and adjust the headlight from the front on a tunneled and frenched headlight set up..
    Maybe from these pictures you can see the parts your looking for.
    I used the Hillman bucket witch has 3 spring loaded screws in it for mounting the base ring and for the adjustments,
    The base ring has 3 slotted holes that allows it to be mounted to the bucket with a twist and for adjusting then the stainless ring holds the headlight to the base..
    Then I welded the ***embly into a sleeve/bucket and welded a 57 ford headlight ring to that and used a 54 Mercury stainless ring to cover everything on the inside.
    Then the complete ***embly is to be welded to the fender giving me frenched, tunneled headlights that can be accessed from the front. 1581483484218~2.jpeg 1581483583892~2.jpeg 1581483673237~2.jpeg 1581483853284~2.jpeg 1581484009125~2.jpeg 1581484142865~2.jpeg 1581484360827~2.jpeg
    Sent from my SM-T387V using The H.A.M.B. mobile app
  10. AldeanFan
    AldeanFan
    That’s excellent, thanks!
    Swap meet season is coming so hopefully we can find something.
    rudestude and loudbang like this.
  11. southcross2631
    southcross2631
    There's an early Morris Minor at the salvage yard I go to. If it ever stops raining in Tn. I can check on them for you. Should be similar .
    Send me a PM if you want me to check them out.
  12. Desmodromic
    Desmodromic
    I love these "G***ers" that are based on small foriegn car bodies. I have a late '50s Austin A35 van (like attached photo) that I am dreaming of using as a basis for a vintage style G***er. What I'm concerned about is whether this car would generally be acceptable, with regards to its wheelbase. I'm not too fond of the cars with extended wheelbase, with the axle in front of the body.
    It's my understanding that NHRA rules of the past required a 90 inch minimum wheelbase. (This is equal to an Anglia's wheelbase; I'm not sure if by coincidence, or it was purposefully set to accommodate Anglias.) I realize there have been various Hillmans, Morris Minors, etc. running as G***ers, maybe not with monster, blown, and/or nitro-fueled engines. The wheelbase of these are several inches short of the NHRA rule. I'm not sure yet of the specific engine I'd use in my Austin (80" wheelbase), but it will be gas fueled, unblown, and less than 305 cid. Maybe even an in-line OHV four, as these are permitted in the local track's flathead cl***, which has handicapped starts. So, I'm not sure whether the wheelbase rules are generally waived for low powered, vintage style cars. Can anyone shed some light on this for me?
    34 GAZ and loudbang like this.
  13. AldeanFan
    AldeanFan
    Thanks for the offer but shipping to Canada would probably make it too expensive.
  14. AldeanFan
    AldeanFan
    You’d have to verify with both the track and the racing series you plan to run with.
    The track sets the rules for safety and tech inspection. If you’re not competing then they’re the only rules you need to follow.
    Many of the safety rules are dependent on speed.
    The racing series will have different rules again so check with them too.
    As for extending the wheel base, you could add some length funnycar style by moving the wheel openings, ***uming you don’t mind body work.
  15. southcross2631
    southcross2631
    Southeast G***ers allows 1 inch on both ends of the car which will make it a whopping 82 inches.
    My Morris had an 87 inch W.B. which is like a Limo compared to your Austin.
    you could hide the extra length in the nose without it looking out of proportion ,of course you must be prepared for some body work.
    Adding the extra room up front gives you more options as far as power for the car.
    ottoman likes this.
  16. AldeanFan
    AldeanFan
    This crazy beast lives!
    We fired it up tonight, just for a moment, will break in the cam on Friday.
    After a lot of adjusting of timing we discovered the coil wire was loose and would break contact when moving the distributor. Our friend Mike solve the issue with a zip tie and it fired up and sounds mean!
    rudestude, James D and loudbang like this.
  17. Shane P
    Shane P
    I am going to try and add a link to the video of the engine actually running rather than just a picture. Sounds awesome
  18. AldeanFan
    AldeanFan
    Now we have a YouTube channel, here’s the first successful start.
    Someone put the timing sticker on backwards so we had some trouble setting the timing.
    Now it’s running pretty good but may need some carb work.
    Shane P and loudbang like this.
