hillman superminx 1962 new ride!!!!
Discussion in 'The Hokey Ass Message Board' started by poprodder, May 14, 2011.
  1. d2_willys
    d2_willys
    from Kansas
    Those tires/wheels don't belong on that Super Minx, hell they wouldn't have a chance on a Sunbeam IMP either. They will fit on a Hillman Husky though.
  2. Zykotec
    Zykotec
    I'm thinking a roof chop will be h**l with that curved rear window, but going full gasser style, with a Euro twist (blown ford v6) would be cool :)
  3. carbuilder
    carbuilder
    What size are your new tires I want some bigger meats under my 59 convertible.
  4. poprodder
    poprodder
    from uk
    thanks guys,
    new tires are 225/60/15 on 6x15" rims.
    cheers chris.
  5. poprodder
    poprodder
    from uk
  6. poprodder
    poprodder
    from uk
    going to mark out rear arches an start cutting!!!
  7. d2_willys
    d2_willys
    from Kansas
    No!!!!! :mad:
    Does that thing have a European license plate on it? If not it should!:eek:
  8. mrjynx
    mrjynx
    Why do they need cutting? the wheels look like they fit, just. also, isnt the door in the way?
  9. poprodder
    poprodder
    from uk
    it has a british license plate on it.
  10. poprodder
    poprodder
    from uk
    not much room in there, had to roll inside of arch this morning after going for a test ride.
    my 12yr old son helped me.
  11. poprodder
    poprodder
    from uk
    picked this up at a autojumble yesterday, cheap fake moon tank.
    cheap enough at £7!!!!
    bloody heavy to start with as it was full!!! until i got home!:D
  12. poprodder
    poprodder
    from uk
    fitted grille back on, still waiting for cap.
    hope the pikeys don't try an nick it!!!!!
    still need to raise front, cut rear arches, and change steering wheel.
    going to keep stock motor this year an change next winter.(no idea what with yet though!!!?)
  13. poprodder
    poprodder
    from uk
    made up a wheel boss from parts laying about,
    heres the wheel fitted.
    and fitted extended spring shackles to rear.
  14. Lunatic
    Lunatic
    from Carson,Ca.
    steering wheel looks good...I have done a few that way too
  15. poprodder
    poprodder
    from uk
    cheers.
    just need a beam/tube now, pity i'm skint
  16. poprodder
    poprodder
    from uk
    had a go today at puttin name on,
    got this much done. still to finish.
  17. poprodder
    poprodder
    from uk
    finished name on drivers side, if it looks rough its because i've never done it before!!!!
    moved onto passenger side, until rain stopped play.
  18. poprodder
    poprodder
    from uk
    looks rather bare without trim!!!
    yep good old redoxide!!!
    undecided on roof colour yet.
  19. poprodder
    poprodder
    from uk
    state of play at the moment, got to do door tops, then a second coat
    all over.
    the other half gave me a hand to rub down, she decided to leave her hand prints on the dry paint!!!
  20. poprodder
    poprodder
    from uk
    second coat applied to everything, bright work back on,
    a bit patchy in places but that'll have to do for now.
    christ the heat has knackered me!!!!
  21. U.K.ROADSTER
    U.K.ROADSTER
    from Birmingham
    Looking good. Cragar cap is brilliant
  22. poprodder
    poprodder
    from uk
    cheers. had it laying around, thought it would look nice.
    this is how hillman looks at moment. trying to get a bigger motor and a beam or tube.
  23. poprodder
    poprodder
    from uk
    updated pics.
    and its now undercover. engine and trans removed and sold.
  24. poprodder
    poprodder
    from uk
    whats that i spot in there!!!
    oh look its a little v6 cologne!
  25. poprodder
    poprodder
    from uk
    got this on the way to fit!
  26. poprodder
    poprodder
    from uk
    this is it!!!!
    austin 10 1947 beam axle.
    amazing stud pattern is 4 stud ford, same as minx!!!
  27. poprodder
    poprodder
    from uk
    no going back now!!! lol
    axle and springs just mocked up, got some work to do to get steering correct etc.
    in this pic it looks too narrow, but needs to be centred etc.
    and engine and box together.
  28. poprodder
    poprodder
    from uk
    some metal work cut out, gearbox lowered and moved back, plenty of room for rad & fan.
    bench seat can stay!
    engine removed, now fitting springs and beam, then back on its wheels for engine& box fitting.
  29. poprodder
    poprodder
    from uk
    this is where i'm upto at present, bit of tidying on front shackles(modified ford pop) still to make rear mounts but slowly getting there, hope to have it back down on its wheels by the new year!!!!
    this could be the last update on here.
  30. Zykotec
    Zykotec
    Looks lovely, and I like the choice of engine (been rebuilding a 2.8 Cologne for years, hoping to get a reliable 200 hp street engine when finished) Just remember that they are filled with oil sludge by now, the cam's worn out, and they are seriously easy to overheat :)
    It sounds awesome with straight pipes :)
