Technical Hinge pin tool
Discussion in 'The Hokey Ass Message Board' started by harpo1313, May 16, 2022.
  1. harpo1313
    harpo1313
    from wareham,ma
    Anyone try the hinge pin removal tool from Drakes yet? I know it hasn't been available till lately but looks to be well made.
    lothiandon1940 likes this.
  2. lothiandon1940
    lothiandon1940
    My friend used one. Sometimes they work, sometimes not. You may have to heat the hinge or even drill out the pin if it is really stuck. Penetrating oil helps. The tool is a quality piece, but has its' limitations.
  3. AVater
    AVater
    I have one and used it a few times with success. Nice tool to have imho.
  4. Hotrodmyk
    Hotrodmyk
    I have one and used it with limited success. As above, heat is your friend .
  5. HOTRODPRIMER
    HOTRODPRIMER
    I had one, use it 3 times and the 3rd time it broke, I should have used heat to encourage the pin to press out. HRP
    Hotrodmyk and lothiandon1940 like this.
  6. Nailhead Jason
    Nailhead Jason
    I used one that a friend had a few years ago on my 39, well i tried to use it. It did nothing. Id say that if the pins have been out in the last 30 years than it would probably work fine. Mine had been in since the car was born and didn't budge. i ended up getting a cheap punch bit for my air hammer and turned it down to just below that size of the pins. That Air hammer had them out in about 10 seconds each. i taped rags and padding to the panels before i did it to proect the OG paint.
    pprather, Kiwi 4d and lothiandon1940 like this.
  7. junkman8888
    junkman8888
    Drilling out the center (core) of the top of the pin helps. It's been my experience that if I don't drill the pin first, any hammering on the small end simply swells the shank of the pin in the hinge and you're screwed.
    alchemy, lothiandon1940 and alanp561 like this.
  8. Kiwi 4d
    Kiwi 4d
    If the pin is worn to have ridges on it and rust to boot, I doubt a jinky little tool will remove it without heat.
    alchemy and Hotrodmyk like this.
  9. I put my Drakes tool in the POS category........did not come close to removing pins that were installed for only 15 years. I use a drift and small hammer.....but remember to protect the surrounding paint.
    Kiwi 4d likes this.
