Hinged seats with storage compartments below?
Discussion in 'The Hokey Ass Message Board' started by tlmartin84, Jan 6, 2014.
  1. tlmartin84
    tlmartin84
    from WV
    Looking to gain some additional storage in my 56' F100, thinking this would be good for storage and maybe other things we like to hide like fuse panels.
    My seats have 4-6" risers below them. I have been debating on how to hinge the seats so they will tip forward. What type of hinges were used etc.
    Does anyone have any pictures of hinged seats?
    Another question is do they need a latching mechanism on the backs or will a shoulder belt hold everything in place?
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    PT Cruisers have comfortable p***enger side seats that have forward tilting seat backs and a storage drawer under them.
  3. patmanta
    patmanta
    from Woburn, MA
    Pictures of YOUR setup would probably help.
    I would say you absolutely need your seats secured. Otherwise they are catapults, seat belts or not.
    You'd be better off looking at seats whose bottoms flip up from the front, like the back seats in my RAM.
    EDIT: I found these things as an example. They appear to be for newer F150 back seats. This should give you an idea of what I'm suggesting.
  4. chriseakin
    chriseakin
    Take a look at a Dodge Journey - the front p***enger seat cushion is hinged at the front and there is a storage compartment underneath.
  5. tlmartin84
    tlmartin84
    from WV
    Anyone else got anything? I have seen them at several car shows especially on bench seats where the bottom flips out. I just failed to take any pictures of them!
  6. Acehole
    Acehole
    from Indiana
  7. tb33anda3rd
    tb33anda3rd
    i am working on making a drawer, that slides out the side of the seat riser, for a customers '38 chevy pickup. he wanted storage and lifting the original seat bottom was a pain to access the space underneath that originally housed the fuel tank. i plan to use drawer slides and building a steel box.
  8. The seat in a pick up only needs to have a good hinge at the front to allow it to tilt forward. The driver will keep it from flipping up or forward, the seat belt holds the driver in, as long as you're wearing the seat belt there is nothing to worry about, if you're not wearing it you should not be driving the truck. The only time you would need to secure the back of the seat base is if it's a rear seat and the vehicle could be driven without anyone sitting in it.
    Now, what I did on my 40 Chevy P-U was remove the gas tank, which was under the seat, then I hinged the seat across the front with a good thick piano type hinge welded to the seat riser and screwed to a plywood base that the seat was mounted to. It worked very well for the 10 years I had it.
    That was almost 20 years ago and I don't have any pictures of it but I think you can picture yours with that set-up, very simple to do. This is one of the only pics I have of the truck.
      227.3 KB
  9. Bam.inc
    Bam.inc
    from KS
    Look up Metaltwister.
    Or pm him to invite him to comment.
    I borrowed this pic of his model a or 32 lift up seat base design, I would like to order for myself.
    I think his company makes lots of sizes. Bengals(SP?)
  10. Bam.inc
    Bam.inc
    from KS
  11. indyjps
    indyjps
    Check out chevy trailblazer and gmc envoy rear seats. The bottom flips up and the top flips forward. If the width is correct this could work out well. You have storage underneath and you can still access behind the seat. Its a split bench, 1 seat on driver side and 1.5 on p***enger.
    Plenty of them with black leather if you can figure out how to get rid of the headrest.
  12. tb33anda3rd
    tb33anda3rd
    finished making the drawer;
  13. tfeverfred
    tfeverfred
    VERY inventive!
  14. motoandy
    motoandy
    from MB, SC
    That sir is a great idea!!!!!!!!!!!
  15. tb33anda3rd
    tb33anda3rd
    thanks Fred. the seat bottom on this truck, '38 chevy, are a pain to lift up and out. unfortunately, do to the size of the riser, there is a lot of wasted space around the drawer. on the other half of the under seat area, he will have to lift the seat to get at the jack, handle, lug wrench and other things that are not needed often.
  16. tb33anda3rd
    tb33anda3rd
    thanks
  17. gnichols
    gnichols
    from Tampa, FL
    You clever guy. Great idea. Gary
  18. tb33anda3rd
    tb33anda3rd
  19. 325w
    325w
    Used a glide seat the cushion folds forward. The EFI electronics are in the storage pan below. Electronics are set up about an inch and a half. Just in case of a heavy rain inside.
  20. tlmartin84
    tlmartin84
    from WV
    Nice work TB. My onlly gripe is the key! Seems like I am lucky to keep up with the few i have.
  21. FolksWaggin
    FolksWaggin
    That worked out beautifully. I like how you matched the drawer face to the ribs in the riser. Did you build the entire drawer from scratch?
  22. FolksWaggin
    FolksWaggin
    In general that's true, but if you have a heavy seat that could be a lot of force against your back in an accident. It would probably be a good idea to have some sort of latch, even if you had to fabricate something.
  23. k32t
    k32t
    from Hog town
    used a tray from my tool box
  24. Coyote13
    Coyote13
    from Dallas, TX
    I've been thinking about rebuilding the seat base on my F250 to include a storage drawer or two, very nicely done.
  25. Jokester
    Jokester
    Check out marine seats. My 32 chev had the hinges set up like them. It was a hinge welded to a hinge. First hinge allowed the front of the seat cushion to flip up and forward about 2 inches. The second hinge allowed the cushion to flip forward from the rear. Sorry, no pics and no longer have the car.
    .bjb
  26. tb33anda3rd
    tb33anda3rd
    thanks tl and Rob the key is what the customer wanted, it made the latching and securing easy. i built the drawer from scratch, but the slides are a hardware piece, if i was to do it over i would use heavier ones [like a file cabinet has].
  27. The37Kid
    The37Kid
    If you use full extention slides you could make a deeper draw.
  28. tb33anda3rd
    tb33anda3rd
    good idea! although a drawer on each side would be better, i left room on the other side for the radio.
