History History (and Build) of Just Steve's 1932 Ford Three Window
Discussion in 'Traditional Hot Rods' started by Roadsir, Nov 26, 2013.
  1. Rocky
    Rocky
    Classified Editor
    Eric...I went back looking for info on what ****** you're looking for but couldn't find it...wasn't it a select-a-shift Olds/Pontiac 6 bolt trans? If so, I MAY have a lead on one. One of my ol buddys junked out a 60 olds with a manual trans and had it laying out on the ground. And he also junked a 56 Pontiac with one. dennys56pontmotorntrans.jpg dennys60oldsmotorntrans.jpg This was about 4 years ago and he came on hard times....sold a lotta stuff to the s****pers. I'll check to see if he still has this, er...."transmission". After blowing 4 of 'em up with my old 57 Pontiac, I don't have a very high opinion of these things but I'll check for ya.
  2. Roadsir
    Roadsir
    Rocky, that second photo looks like an olds ******. Let me know what you find out. Sounds like having a full spare would be a good thing!
  3. F&J
    F&J
    Now that you found out you need Olds trans parts instead of Pontiac...
    I started looking, and so far I have:
    -NOS speedo "driven" gear with it's NOS screw-in adapter. I test fit on a 53 Olds unmolested trans, and it meshes good, and turns by spinning the mainshaft.
    -NOS cork seal for input shaft. If it was fresh stock, you had to soak in boiling water to expand it to get it on. I don't think there is a product that could permanantly soften "old' cork...but at least you can see how to shape a new one.
    -a USED "drive gear that presses onto the mainshaft. I'd need to pull the shaft out to press it off.
    -I found old NOS gasket packages with part number labels, if you need the numbers? If you did not know, you need a full face gasket between trans and bell. Also, the bell housing needs a hole on it's face for the Roadmaster p***enger side shift rail to clear. It's info in my Buick trans thread on hamb. I forgot to look at your bell so I don't know if it is like an old Offy bell I had, that already has that hole.
    In the meanwhile, put up two pics of your rear trans yoke, so I can see what retainers you need. The yoke may not be Olds, so I don't want to search yet.
    other pic would be of the welded-on yoke on the front of the driveshaft, to also see what retainers. Both pics taken looking at the round U'joint cup face side.(threaded holes? etc)
  4. louisb
    louisb
    Great build, your brother would be proud.
    --louis
  5. Roadsir
    Roadsir
    F&J, Thanks
    - On the cork seal. I found a source that is selling a large diameter o-ring. I think I will give that a try.
    - Gasket set. I did find a full gasket set from "BEST"
    I am intersted in the both the drive gear and driven gear. I will shoot you a PM.
    Thanks
    Eric
  6. Roadsir
    Roadsir
    Thanks Louis
  7. Roadsir
    Roadsir
  8. Rocky
    Rocky
    Classified Editor
    Eric...my buddy says he still has a ****** for $150. PM me if you want me to go take a look at it and take some photos.
  9. Roadsir
    Roadsir
  10. Roadsir
    Roadsir
    Decided to make a few header badges before getting them coated
    Runnin shine, Katman1 and loudbang like this.
  11. Looking good!
  12. Roadsir
    Roadsir
    Been a long time since I posted progress. I took a few weekends off to winterize, but we're back on track now.
    Yesterday I finished up most of the brake line plumbing.
    I think I will paint the residual pressure valves.
    I decided to re-use the old bone brackets as shock mounts. I swapped them side to side.
    It took a little heating
    And a little fab using some pre-stamped ears.
    And a little test fit.
    Waiting on a flywheel so that I can ****on up the drivetrain.
    Runnin shine, loudbang and Katman1 like this.
  13. AHotRod
    AHotRod
    Beautiful workmanship, very well done.
  14. Corn Fed
    Corn Fed
    Looking really good. I love seeing old Ford stuff reused for purposes not necessarily as they were intended. I can't wait to see your coupe in person.
  15. Roadsir
    Roadsir
    Thanks guys, I appreciate it.
  16. Shock mounts are pretty slick!
    Great re-use
  17. Roadsir
    Roadsir
    Here's an update. I'm closing in on one year as I brought the car home late November, and a little behind my goal of having it fired in 12 mos. I don't want to press it.
    I found out 56 Buick clutch and pressure plates are a little unique. So I bought a 55 pressure plate, clutch disc from Kanter, and found a 55 flywheel that is on its way. Once I get that faced I can ***emble the drive train.
    I'm using a 1958 aluminum water pump and sending it to Flying Dutchman Water pump rebuilders in Selma Oregon. Once this gets back I need to get the pulleys on and fab a generator bracket.
    Contacted ****ster for a pair small flange Rochester 2gc's, for the Edmunds 2-2, and I'll get a few Edmunds air cleaners
    I hope to get the headers to a coater on Friday, rebuild the starter, generator, order a radiator, wiring kit............
  18. 3wLarry
    3wLarry
    from Owasso, Ok
    patiently waiting is over rated :D
    kidcampbell71 and loudbang like this.
  19. NealinCA
    NealinCA
    I really like the rear shock mounts...might have to "borrow" that idea...
    Neal
  20. Roadsir
    Roadsir
    I tried two methods and decided on option one.
    1. swapping the bone brackets side for side facing rearward using the two lower holes on the axle tube.
    2. keeping the bone brackets on there original respective L and R sides but rotating them 90 degrees to use the back two holes on the axle tube.
    While both options could work, and you could argue option 2 would be stronger, option one seemed to look better and I think option one will be quite strong.
    I studied pics of the aftermarket cast brackets, but it just looked like lower eye was going to be outside the 36 bone and would need a lot of shock angle for the shock to clear the bone itself.....
  21. Roadsir
    Roadsir
    I also had some F1 front brackets that I was holding up to the rear but wasn't feeling it...
    Then I see Steadfast just advertised these in the cl***ifieds. It might be possible to make a bracket that picked up 2 or 3 backing plate mounting points and use bolt on shock front shock brackets.
    Kinda cool on the right car.
  22. 3wLarry
    3wLarry
    from Owasso, Ok
  23. kidcampbell71
    kidcampbell71
    Hey man.....happy birthday ! Hope you put some pretty shocks of choice on your cake ! If you're like me, a *****ie is nothing to a great piece of meat.
    Love your stuff as you well know.....but today you got sold out on the front page ! :) Have a good day today man.
  24. Roadsir
    Roadsir
    Hit a milestone yesterday. Thanks!
  25. T Hudson
    T Hudson
    Sounds painful. o_O You couldn't have just said you reached it? Now I'm gonna be worried for 6 months. :eek:
  26. Sure enjoy watching this come together.
  27. 383deuce
    383deuce
    Same here......Keep it going as it is looking great.
  28. Roadsir
    Roadsir
    Thanks guys,
    Still waiting on the clutch, pressure plate, a flywheel, water pump, all enroute.
    Had a fun conversation with ****s Hot Rod Carbs, and looking forward to getting the Rochesters
    Got the the shocks tightened up, rear wheel cylinders are in, brakes are in and I can finish the rear lines tomorrow.
    On the rear hubs I cut the studs flush, and pressed them out. Not sure if I will use original swage style or drill them larger for conventional knurl. These measure .550/.556 not. .625 like some.
    Ive been studying the DORMAN catalog.
    Heres the swage tool has anyone used this with any success.?
  29. TerrytheK
    TerrytheK
    Well, if it makes you feel better I'm closing in on three years for a mere engine swap and a brake upgrade.
    Besides, if a "build thread" ends when the car's on the road.... well, we wouldn't want THAT to happen too soon 'cuz I'm enjoying this one! Great work.
  30. ago
    ago
    from pgh. pa.
