History History (and Build) of Just Steve's 1932 Ford Three Window
Discussion in 'Traditional Hot Rods' started by Roadsir, Nov 26, 2013.
  1. Roadsir
    Roadsir
    That looks really familiar. I actually might put the horseshoes back in. It appears our motors are sitting in similar positions. What did you end up running for exhaust?
    In my excitement to get the motor and******* back in the car, and headers on, I completely forgot to check fit a left side Belond header that I found mid-build. I'll have to hold it up tomorrow.
  2. Detonator
    Detonator
    from santa cruz
    My frame's pinched a bit so I had even a bigger************ going on with the motor mounts, steering box, starter, clutch linkage etc. I took the easy way out and ran the exhaust outside the frame rails. I also ran a "pull" style slave cylinder for the clutch arm, it put this mechanism behind the bell housing.
  3. Roadsir
    Roadsir
    Looks great, that is a tight fit.
  4. Roadsir
    Roadsir
    Here's are a few pics of the wiring harness so far. I have some black leather look firewall insulation enroute so the panel and wiring will need to come off one more time.
    Here's where the battery ended up. It's a snug fit.
    I also worked on springs for the clutch and brake pedal. Brakes are ready to bleed. I need to get the rear hubs back on.
    Tonight I made plugs wires, and got the distributor set in. It will need to come out to prime the pump.
  5. Roadsir
    Roadsir
    Picked up my driveshaft today. I used a 56 olds Pontiac manual transmission shaft as the******* yoke and u- joint are somewhat unique. I think I might buy another joint off EBAY to insure I'll have a spare.
    The shop thought they would do me a favor and rattle canned it over the rust so I had a little work to do prep. ( so I could rattle can it properly! )
    Started modifying a 32 spoon pedal. I removed the arm from the original shaft.
    I measured the pull distance on a Rochester 2bbl at 1 3/8" travel.
    Then layed out the firewall and floor angle on a piece of cardboard and played around with some different positions and arm lengths before finding a good compromise, for spoon travel and height both at idle and full throttle.
    I laid out an arm and cut it out of 3/16 steel. I'll weld this together.
    The pedal has a bore just under 5/16". I'll open just a little to press in an oil lite bushing and use a 1/4" bolt for a cross shaft. More to come.
    cully33 and daddio211 like this.
  6. daddio211
    daddio211
    Way cool.
    Roadsir likes this.
  7. Roadsir
    Roadsir
    Got the pedal done. Need to paint it black tomorrow.
  8. T Hudson
    T Hudson
  9. willysguy
    willysguy
    from Canada
    Very cool indeed, this project just keeps getting better in all the neat little details!
    Roadsir and 1927graham like this.
  10. Wow! What a treasure trove of build shots! I stopped by Kurts shop and met him not long after Steve passed. It was not far from where I lived and the bike shop I worked at in Blaine
    Roadsir likes this.
  11. Jeremy Jalopies
    Jeremy Jalopies
    I just went through all 15 pages thus far and what an awesome story! My condolences on your loss but man this is timeless. I look forward to the rest. Best wishes
    Roadsir likes this.
  12. Roadsir
    Roadsir
    Today I made some headway on the alternator bracket. I wanted to give it an oem look. It's close to everything around it but it clears the motor mount, engine, and the drag link just clears through the suspension travel. I need to make an adjustment bar, and maybe punch a few holes in the bracket for looks.
  13. The bracket looks good. That's a mini alternator isn't it? I wanted to put one on my roadster, but chickened out. now every time I open the hood and see that big old alternator, I kick myself for not stepping up and buying a mini alternator. Any how great job!
  14. Roadsir
    Roadsir
    Yes, it's a 50A. It's small and light, and there inexpensive. There are quite a few sources on EBAY to get them in 30-60Amp ranges.
    I got to looking at the Generator, how much it weighed, how much it would cover up the Edmunds stuff, and decided to make a concession.
    Runnin shine and loudbang like this.
  15. Pinstriper40
    Pinstriper40
    It's good to see progress on this car, that gold nailhead is the cat's meow! Keep having fun with it!
    Roadsir likes this.
  16. Roadsir
    Roadsir
    progress is at a snails pace of late. I did get the alternator bracket lightened and painted. It just needs a tension bracket. It's hidden pretty well.
    I received the carbs on Friday. One was damaged in shipping so I shipped it back on Saturday.
    The mini-starter fitment has caused a few fits as well. It has multiple holes to clock the rear mount. The set I need to use have a bolt circle at least .020 off so it's heading back tomorrow.
    We sold Steve's bugeye a month or so ago. The new buyers hired a transport company and they were about three weeks late from their three day window. They called Friday and said they would be picking it up Saturday! So I had to make a quick run to to Wisconsin to make sure it got loaded ok for its new home in Hood River Oregon. A little bittersweet, the car is going to a great new owner and I think he plans on doing some tracks days and auto crossing with it.
    volvobrynk, daddio211 and Welderboy60 like this.
  17. Dick Stevens
    Dick Stevens
    That bracket sure turned out looking great, I never cease to be amazed at some of the things that guys on the HAMB come up with. ;)
  18. Roadsir
    Roadsir
    Well some progress. Got the last carb back. I found the Rochester bases were not going to seal, and I needed to make some adaptors. I was just getting ready to cut and drill them with a hole saw when Rusty stopped by and said he would machine them. A few hours later I had these.
    And installed.
    And one last pic of the alternator with the adjuster in place
    loudbang and volvobrynk like this.
  19. cully33
    cully33
    This coupe just gets better, every time I check it out, doing a great job there Eric.
    Roadsir likes this.
  20. Roadsir
    Roadsir
    It's been some time since I last posted. Some work was a little trivial, but yesterday I got the radiator and grille shell in place, and today I decided to put the body back on. Here's a few pics.
    Getting ready to use my lift.
    Nearly a 150 years of shop experience helped get the body on the frame
    A rare photo with me in it.
    And one without. Time measure for some tires, so I placed a rear fender on.
    Katman1 and volvobrynk like this.
  21. cully33
    cully33
    Looking fantastic.
    Roadsir likes this.
  22. Cool.
    Al.
    Roadsir likes this.
  23. Rocky
    Rocky
    Classified Editor
    Damn, Eric! I can't believe how much you look like your dad! Love the quality of work you're doing on that coupe. Steve would approve....very nice.
  24. Hotrodderman
    Hotrodderman
    Eric,
    I Just went through the whole thread again tonight. Wow! I forgot how much work was done to the frame before you got it. The car looks great! How did it go fitting the body on today?
    Chris
  25. Roadsir
    Roadsir
    Thanks Rocky, I appreciate it!
  26. Roadsir
    Roadsir
    Chris,
    Went pretty well, the lift worked great to lower the body down and no major surprises. The only gotcha is the fuel line out of the tank sending unit is unconfortably close to the a drop down in the floor. I might make an opening for an inspection plate, and a cover that gives a little more clearance.
    Having fun now!
  27. Great car, great thread.
    Thanks Eric, appreciate the detail
    Cheers,
    Drewfus
    Roadsir likes this.
  28. studebaker46
    studebaker46
    that picture of you with the smile on your face says it all im sure steve is smiling just as big
    Roadsir likes this.
  29. thunderbirdesq
    thunderbirdesq
    VERY cool!
    Roadsir likes this.
  30. Blue One
    Blue One
    from Alberta
    I like the gas pedal, as well as everything else. Nice job. :)
    Roadsir likes this.
