History History (and Build) of Just Steve's 1932 Ford Three Window
Discussion in 'Traditional Hot Rods' started by Roadsir, Nov 26, 2013.
  1. Roadsir
    Roadsir
    As long as it took to get the fricken bar aligned to the braces I can see why guys don't run them!
    volvobrynk and 3wLarry like this.
  2. Dick Stevens
    Dick Stevens
    But they look so damn good with fenders! :cool:
    volvobrynk likes this.
  3. T Hudson
    T Hudson
    Should have just welded it on o_O
    It was a great time. :cool:
  4. PRIMER STUDIO
    PRIMER STUDIO
    from Butte,MT
    Love the fenders. Looks Awesome!
  5. T Hudson
    T Hudson
    I think the fenders give it a great look.
    Putting riv-nuts in the frame was more of a process than Eric let on. The holes for the forward hood latches were obscured by the step boxing plates. A drill guide was made and careful clamping and drilling followed. Other than the dropped headlight bar giving trouble all the fender to frame bolt holes lined up perfectly, after slight m***aging for motor mount and steering box bracket clearance.
    Bleeding the brakes went pretty well, a little m***aging of the floor board for pedal travel and one little drip at the residual pressure valve.
  6. Roadsir
    Roadsir
    I didn't mention that I gave up on trying to find a space for the lever actuated brake light switch and decided to put an in-line pressure switch.
    Does anyone else wish they made the lever switches in left and right swings?
    daddio211 likes this.
  7. Six Ball
    Six Ball
    from Nevada
    They used to but I wish they still made a lot of parts that they don't anymore.:( Can't you turn it over?
  8. Roadsir
    Roadsir
    Possibly
    It looked like the wiring would be headed for the clutch pedal.
  9. Roadsir
    Roadsir
    Well, got the tank out. I rinsed it with water and simple green, then per the red kote instructions I put in a quart of acetone. The tank flange leaks so bad that it soaked a towel I had the tank setting on (to protect the paint) which proceeded to soften and blister the paint.
    Since it will need a re spray Might as well replace the tank.
    It's a "Tanks" tank. I'm going to give them a call tomorrow.
  10. DDDenny
    Ruh--Roh!!!
    I guess I'll be checking mine before it gets painted.
  11. Roadsir
    Roadsir
    Decided to switch to something a little more fun. Started making the panel for the gauge insert.
    It's only going to hold three gauges, so I need to figure out a place for two more.
    Before I had the dash painted I spot welded three tabs to the dash to hold the insert.
    BONNEVILLE BOB 95 and daddio211 like this.
  12. 383deuce
    383deuce
    DAM! That dash is purty....
  13. loudbang
    "Before I had the dash painted I spot welded three tabs to the dash to hold the insert. "
    The dash is a prefect example of prior planning prevents piss poor performance. Especially when cold ones and a beer ***istant are involved. :rolleyes:
  14. I just know you want to do the same thing I did..! ;)
    You don't seem to have put a foot wrong so far - so I imagine you'll find a great solution to this little dilemma too!
    Dave
  15. scoop
    scoop
    Gonna make Back to the 50's?
  16. Roadsir
    Roadsir
    Thanks. I'm thinking of making a 2 gauge lower panel and also the key and choke.
    I like your door panel design as well. Hmmmmm
  17. Roadsir
    Roadsir
    Tanks was very fair and helpful even with the tank being 10 years old.
    I was even wondering if it was a photography sample as Steve did a fair amount of add work. Hard to tell, but a new one should arrive Thursday. I need to get it sprayed...... Quick
  18. Roadsir
    Roadsir
    It should make it. I'm running out of time for a shake down cruise with the tank issue.
  19. Roadsir
    Roadsir
    My work travel schedule has let up, and my garage is 2 blocks from work, so I am trying to pick some 15-30 minute tasks I can get done during lunch.
    Like hanging the front bumper.
    And my garage is pretty small so it's tough to get a good shot of the profile. Here's an attempt.
    Kilroy
  20. Dick Stevens
    Dick Stevens
    That is great to hear that Tanks is helping you out on a new old tank that of their's that leaks.
  21. T Hudson
    T Hudson
    I see you remembered to pick up headlights. Bumper looks good.
    Keep me updated on John's bike project.
  22. Roadsir
    Roadsir
    Wednesday night I ran the tank over to Travis to spray, he just sent a text that it will be ready to pick up tomorrow at noon.
    Not to much of a set back in the grand scheme of things.
    Here's a pic he sent.
  23. T Hudson
    T Hudson
    Did you test it for leaks first?
  24. kidcampbell71
    kidcampbell71
    Wow ... be sure to tell him tank you. :)
    loudbang and volvobrynk like this.
  25. lewk
    lewk
    from Mt
    Cool project! You build hotrods on your lunch break? I just stare at the HAMB and scratch myself.
  26. Roadsir
    Roadsir
    Actually I didn't, I see that state they are leaked tested twice. The weld seam looks better.
    Ha hah!
    Well not everyday...
  27. Roadsir
    Roadsir
    The rear bumper bracket taillight ***y really fought me. But I finally got all the body stuff on and rolled it out for a few pics.
    Dash, column, hook up headlights and taillights, windshield, seat, set the brakes and it's ready for a drive.
    ImageUploadedByH.A.M.B.1433709725.083343.jpg ImageUploadedByH.A.M.B.1433709815.192826.jpg
    Malcolm, lewk, Finn Jensen and 4 others like this.
  28. Dick Stevens
    Dick Stevens
    I absolutely love it! That is what a deuce coupe should look like! :cool:
  29. Roadsir
    Roadsir
    After the pics above the skies opened up and we got a helluva lot of rain. I got back in just in time.
    I needed to get the lower gauge panel and headlight panel made so I can get them tig'd during the week.
    Key will be on the left, two gauges in the center, and choke on the right. I'll have room for a heater switch between the two gauges.
    I also made a headlight switch panel for the left side of the dash.
    loudbang and T Hudson like this.
  30. T Hudson
    T Hudson
    That is looking slick!
