Hole saws for gauges (2 1/8" & 3 3/8")???!!!
Discussion in 'The Hokey Ass Message Board' started by retiredfireguy, Mar 11, 2010.
  1. retiredfireguy
    retiredfireguy
    Does anyone know of a place where I could buy 2 1/8" and 3 3/8" hole saws" I want to install gauges in a fiberglass dashboard, and I cannot find any hole saws in these sizes. Thanks for any info.
  2. LowFat48
    LowFat48
  3. johnboy13
    johnboy13
  4. Fat47
    Fat47
    Fastenal or find an electrician who has a hole punch for commercial panels.
  5. I cut four hole in my glass dash with a hole saw but the oversize speedo took more work. I drew a circle around the gauge on the dash and drilled a pilot hole in the center. Then carefully cut out the hole with my jig saw - ended up with a rough edge but this is covered up by the bezel on the gauge. So far so good!
  6. Roothawg
    Roothawg
    I bought mine at a local hardware store. I had to buy the quick change arbor.
  7. waltspuffer
    waltspuffer
    any company that handles Black and Decker, and you will have to buy the arbour
  8. rockable
    rockable
    +1 on Fat47's suggestion. Find an industrial electrician who builds panels. He can hook you right up.
  9. 32Essex
    32Essex
    from Texas
    I always go to the next size smaller and finish the hole to size with a carbide burr.
  10. Some electricians might use hole saws, but mostly they use punches - either hydraulic or hand powered. They work great on sheet metal, but not at all on fiberglass. They come in conduit sizes, not fractions. I used them for my Auto Meter gauges - they get you a nice round hole and close to the size, then 1/2 round file after that.
  11. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    I buy them at the local Ace hardware. Millwaukee brand.
  12. 61bone
    61bone
    Tool Depot, Grainger, Rutland,
  13. Here are the ones in Washington:
    <table class="zebra-grid fixed paginated"><tbody><tr class=""><td style="white-space: nowrap;">Store Code: WAMOU
    Mountlake Terrace, WA 98043 </td> <td> 7116 220th Street SW
    P: (425)775-4506
    F: (425)775-7069 </td> <td> Make WAMOU your default store
    </td> </tr> <tr class="altcolor"> <td style="white-space: nowrap;"> Store Code: WAEVE
    Mukilteo, WA 98275 </td> <td> 11524 Mukilteo Speedway
    Mukilteo, WA 98275
    P: (425)315-9202
    F: (425)315-9459 </td> <td> Make WAEVE your default store
    </td> </tr> <tr class=""> <td style="white-space: nowrap;"> Store Code: WABOT
    Bothell, WA 98012 </td> <td> 17903 Bothell Everett Highway
    Bothell, WA 98012
    P: (425)489-3460
    F: (425)489-3962 </td> <td> Make WABOT your default store
    </td> </tr> <tr class="altcolor"> <td style="white-space: nowrap;"> Store Code: WASE2
    Seattle, WA 98107 </td> <td> 920 NW Leary Way
    Seattle, WA 98107
    P: (206)781-6908
    F: (206)781-6965 </td> <td> Make WASE2 your default store
    </td> </tr> <tr class=""> <td style="white-space: nowrap;"> Store Code: WAWOD
    Woodinville, WA 98072 </td> <td> 16110Woodinville-RedmondRdNE
    P: (425)424-2318
    F: (425)424-1298 </td> <td> Make WAWOD your default store
    </td> </tr> <tr class="altcolor"> <td style="white-space: nowrap;"> Store Code: WABE1
    Kirkland, WA 98034 </td> <td> 11145 120th Ave NE
    Kirkland, WA 98034
    P: (425)827-7058
    F: (425)827-9289 </td> <td> Make WABE1 your default store
    </td> </tr> <tr class=""> <td style="white-space: nowrap;"> Store Code: WASE4
    Seattle, WA 98121 </td> <td> 2229 7th Avenue
    Seattle, WA 98121
    P: 206-239-0358
    F: 206-239-0360 </td> <td> Make WASE4 your default store
    </td> </tr> <tr class="altcolor"> <td style="white-space: nowrap;"> Store Code: WARED
    Redmond, WA 98052 </td> <td> 9145 Willows Road
    Redmond, WA 98052
    P: (425)869-4878
    F: (425)869-5672 </td> <td> Make WARED your default store
    </td> </tr> <tr class=""> <td style="white-space: nowrap;"> Store Code: WAEV1
    Everett, WA 98201 </td> <td> 3301 Cedar St.
    Everett, WA 98201
    P: 425-252-7219
    F: 425-259-0645 </td> <td> Make WAEV1 your default store
    </td> </tr> <tr class="altcolor"> <td style="white-space: nowrap;"> Store Code: WASE3
    Seattle, WA 98134 </td> <td> 624 South Lander St.
    Seattle, WA 98134
    P: (206)264-0198
    F: (206)264-7941 </td></tr></tbody></table>
  14. Hotrod7
    Hotrod7
    make sure your arbor is true and the saw is really REALLY round. old abused equipment is notorious for making holes way to big lol, never fun to deal with.
    A couple people sait it already but its generally a safer bet to go a bit smaller and file your way up, do it by hand or be really careful and use a burr bit
    edit: just saw your dash is glass dont use a burr bit lol it'll take material away to fast. just use a file :)
  15. retiredfireguy
    retiredfireguy
    Thanks everyone! Found what I was looking for. Seems like H.A.M.B. is where I always find answers that I can't find anywhere else.
  16. A trick that works for me is to drill pilot hole ( 3/16 or whatever comes with the holesaw) without the holesaw...clamp a short piece of round stock the same size as the pilot hole into holesaw in place of pilot bit to use to center the sawn hole...less chance of wobble and a cleaner hole
