Hole Saws
Discussion in 'The Hokey Ass Message Board' started by REDDOG, Feb 11, 2008.
  1. REDDOG
    REDDOG
    is it me or has any one else noticed the decline of the quality of the hole saws in the last 5 yrs or so, i still think starret makes the best hole saw, but i use to be able to go to home depot and pick up a hole saw and do a complete ch***is with it, now it seems its only good for about 10 notches and then seems to get real dull, or i use a new one and it snaps half the teeth on it on the first shot, just wondering if any one has found a hole saw that has worked for them
    johnny
  2. ryno
    ryno
    lenox or fastenal's brand.
  3. i second lenox ..i have a bunch of them i've used for years
  4. Lostrebel
    Lostrebel
    Yeah them ones the depot sells are junk and there not too cheap I bought one to drill the holes in a model A axle I have and it only cut a half of one hole and was junk so I went to Grainger Industrial supply and got a morse hole saw it drilled all 17 holes and is still good and it was 4 bucks cheaper than the one at home depot.
    http://www.grainger.com/Grainger/ww...ntSearch&originalValue=hole+saws&L1=Hole+Saws
  5. I word: China. I used a Lennox with LOTS of lube to drill several holes in 1/2" plate the other day, worked great, just a little slow in my soon-to-be repalced China drill press, kept slipping the belt and bogging down.
  6. You know when I drilled all the holes in the T frame I used Ace Hardware's brand holesaw since they were out of the Milwaukee I needed. I'll be dammned if that cheapie didn't do a great job of the 32 holes it had to bore!
  7. Ranunculous
    Ranunculous
    I always try to buy Bi-Metal blades when possible,even then the quality on some is sub-standard.
    Lenox,Starret and Milwaukee seem to always work well.
    Once I start a cut,I don't stop til the work is parted.
    It seems the blade loses its temper or interest in finishing the kerf?
  8. Another thing you can do is to drill a small thru hole on the perimeter of your hole for the chips to fall through.
  9. I find that I wear out hole saws pretty quickly on my drill press - a combination of too much speed and a lot of arbor wander. Same saws with my mill at 120 rpm seem to last almost forever and are a lot more accurate. I use Starretts almost exclusively.
    Charlie
  10. Anyone ever though of using GreenLee Punches ? I know they are expensive but they don't wear out. They are available up to 2 3/8 holes and 10 (0.134)gauge sheet metal
  11. MetalMike
    MetalMike
    Heres a tip from lil john buterra, Drill 3 holes, a pilot hole, then 2 more 180 from each other, just inside the diameter you are cutting. It keeps the bit cooler, and allows the cutting debree a place to go.
  12. TxRat
    TxRat
    I use the craftsman bi metal hole saw blades. lots of lube and let the cutter do the work. Ive had them for a few years now and are still sharp and cut clean..
  13. Mistic Metal mover helps the cutting, I know there are other cutting fluids out there.
  14. 35WINDOW
    35WINDOW
  15. MetalMike
    MetalMike
    I have a complete blaire cutter set from snap-on. Mostly use them for holes in sheetmetal, every once in a while I use them on stock, Very nice tool, I don't think they make them very big though...
  16. Professor Fate
    Professor Fate
    from the bay
    good idea. will give it a go.
  17. zbuickman
    zbuickman
    For holes I use lennox . and other Bimetal holesaews for so-so holes. seem to last a long time for me. need a slow drill though. and for nicer holes I use a carbide hole cutter. and for the neatest holes I use my slugsplitter hydraulic drawstud punch. in sizes 7/8" to 4-1/2":) and the slugsplitter will pull 1/8" 304 stainless or 3/16" steel
  18. Scott
    Scott
    Lennox and cutting oil
  19. Wild Turkey
    Wild Turkey
    My dad cut 2" holes in stainless steel using a holesaw (don't remember the brand) by putting a weight on the end of the long handle on the OLD SLOW flat-belt drill press.
    He get the bit to cutting, put the lube/coolant nozzle on it, and walk away.
    Took a while, but got good clean holes and hole saws lasted a long time.
  20. HHRdave
    HHRdave
    from So Cal
    I use aircraft hole saws with carbide tips, they cut through anything.....work great at slower rpms.
    They look something like this set here:
  21. lehr
    lehr
  22. Dakota
    Dakota
    from Beulah, ND
    rotabroaches are nice, im just gonna use a big Carbide endmill when i drill my axle..
  23. Where can I get some of those?
