Technical Holes in Rochester Carbs
Discussion in 'The Hokey Ass Message Board' started by oj, Oct 6, 2024.
  1. oj
    oj
    Can anybody offer up a guess what these are intended for?
    This base is from a 3x2 primary carb, it has a single .105 hole drilled (see my plug gauge)
    The 2 end carbs have 2ea .085 holes drilled, see the plug gauges inserted in the drilled holes:
    These holes are ABOVE the throttle blades, they only see vacuum when the throttle is opened, what purpose are the serving?
    Thanks, Oj
    lothiandon1940 likes this.
  2. Joe H
    Joe H
    They wanted vacuum leaks !
  3. oj
    oj
    To what purpose, what condition are they trying to correct?
    It wouldn't be a vacuum leak unless the hole was drilled below the throttle blades.
    hrm2k and lothiandon1940 like this.
  4. oldsmobum
    oldsmobum
    from SoCal
    I have never noticed anything like that on any of mine. I am going to guess they should not be there at all. If someone wiser does not set this straight before then, I will inspect mine when I get home later today. I have a set of 3x2 bases from Charlie Price.
  5. Mike VV
    Mike VV
    from SoCal
    Those holes are NOT...vacuum leaks !!
    To be a vacuum leak, they'd need to be "under" the ****er-flys, NOT above.
    As to the "exact" reason they are there, I was not part of the design team, so...I don't know. People can guess as much as they like, but I'd like to hear from a design team member...
    Mike
  6. 48stude
    48stude
  7. hepme
    hepme
    Had a set of original Pontiacs (avatar)and no holes. Guess: keeps fuel pressure even across the set, blades open and still even and smooth. JB weld cures teeth and these.
  8. oj
    oj
    Holy ****, thats my own thread! damn, I do not remember that. Well, that answers that, yes this is a different set of carbs, very professionally done - well, other than not working (I've found that they had aftermarket floats that were too long by a few thousandths and wouldn't let the float shut off the needle & seat, the float rubbed the fuel tower for the accelerator pump).
  9. lothiandon1940
    lothiandon1940
    .....@oj...Your memory is as short as my........oh, let's not go there.:D:D:rolleyes:
  10. oj
    oj
    How odd, I was thinking the same thing, that my memory was as short as yer pekker!
    lothiandon1940 and Budget36 like this.
  11. Jagmech
    Jagmech
    See Doug Roe's Rochester Carb book, pg. 68. Those are factory holes for hot engine start vapor release. A vented gasket was also used. No more holes after 1970-71, emissions reasons . Leave as is or plug if you want.I leave them open.
    jet996, lothiandon1940 and oj like this.
