HOLES THREAD...drilled axles,backing plates,anything.lets see'em
Discussion in 'The Hokey Ass Message Board' started by a.y1320, Mar 21, 2009.
  1. loudbang
  2. loudbang
  3. Just Gary
    Just Gary
  4. nochop
    nochop
    from norcal
    A15418A5-3BE6-4585-AA06-F63FB1BF0D78.jpeg My 2 cents today
    Jim Bouchard and loudbang like this.
  5. nochop
    nochop
    from norcal
  6. Drilled out SoCal Axle
    DrilledAxle1.JPG DrilledAxle2.JPG DrilledAxle3.JPG DrilledAxle4.JPG DrilledAxle5.JPG DrilledAxle6.JPG DrilledAxle7.JPG DrilledAxle8.JPG DrilledAxle9.JPG DrilledAxle10.JPG
  7. Drilled, Dimpled & Chromed Lincoln Backing Plates BrettsRoadsterUpgrades310.JPG IMG_0351.jpg
  8. nochop
    nochop
    from norcal
  9. seb fontana
    seb fontana
    from ct
    BIG Holes!
    kadillackid, Just Gary and loudbang like this.
  10. loudbang
    Holy moly that is a BIG pile of metal chips. :eek:
    kadillackid likes this.
  11. nochop
    nochop
    from norcal
    So lite…it floats
    kadillackid, loudbang and Just Gary like this.
  12. loudbang
  13. loudbang
  14. loudbang
  15. mad mikey
    mad mikey
  16. Dan Timberlake
    Dan Timberlake
    The chips look nice and long, like the (cast?) axle maybe is a fairly ductile steel.
    https://www.dura-bar.com/advantages/material-advantages/alternative-to-steel
    That's a good thing.
    I'd spend some time deburring, blending and smoothing the hole edges.
    Going over a one wheel bump the axle will be twisting a bit, and the stresses at some spots around those hole are probably quite a bit higher than in the original I-beam.
    I usually break out the spot-check/dye penetrant spray cans on hard working parts.
    A can of 2nd tier penetrant and a can of developer ought to be less than 25 bux. A few cans of chlorinated brake clean will do the cleaning prep as well as the official cleaners that often are over 10 bux/can,
    A crack rarely gets better in service, and sometimes grows pretty quick.
    Severe porosity in a casting can indicate bigger problems below the surface, or even start trouble on its own.
  17. loudbang
  18. loudbang
  19. loudbang
  20. Just Gary
    Just Gary
  21. DDDenny
  22. Nobey
    Nobey
    Here's one we are trying to find some history on. 31 body on a 32 frame, ran a flathead and was drag raced
    in the central valley of California. Anyone recognize it???? It's got holes..... Image 9-30-22 at 2.10 PM.jpg
  23. Pete1
    Pete1
    from Wa.
