HOLES THREAD...drilled axles,backing plates,anything.lets see'em
Discussion in 'The Hokey Ass Message Board' started by a.y1320, Mar 21, 2009.
  1. The axle was drilled at school by students in the machine shop. Also their first. I drilled the shock mounts to match the motor mounts
  2. GuyW
    GuyW
    True. And I'd add, "It's a fine line between what's actually (mechanically) effective, and what is just aesthetics"
    Once upon a time in hot rodding, form followed function....
    ....but by all means, follow your own muse(s)...
  3. lostforawhile
    lostforawhile
    well from an off topic car, but the plate that replaces the ashtray under my dash,mounting for the speaker for the voice warning system. long story-1970's electro mechanical voice warning system :D all this work for something no one will ever see, it's hidden by the center console [​IMG] wait,those are when they were center drilled let me find the correct picture
  4. lostforawhile
    lostforawhile
    ok correct picture[​IMG] I thought i had a picture all painted with the center console illumination and everything,but i guess not
  5. Mark H
    Mark H
    from Scotland
    Didn't have a hole saw so the slots in my frame were chain drilled and filed by hand.**** me ,it took ages!Other shot is my trans cross member.
  6. 26T
    26T
    from Denver
    Dude, hole saws are not that expensive! Nice work though.
  7. Mark H
    Mark H
    from Scotland
    Know what you're saying but,I would have had to wait a couple of days for them and was too impatient!Thing is,if I'd waited the job would probably have been done quicker!
    And thanks for the compliment!
    Cheers,Mark.
  8. Handbult header flanges
  9. philly the greek
    philly the greek
    from so . cal.
    thought I'd lighten up the deck lid hindges!!
  10. Fordguy78
    Fordguy78
    I found this in a story on Yahoo today. I know it's not a hot rod part but if you ask me, it's pure hot rod thinking.
  11. langy
    langy
    I thought the same :D
  12. panic
    panic
    Very nice, but it rather high-lights the difference between careful craftsmanship and attention to detail... and engineering.
    Some of those are a fatal accident hanging in mid-air.
    Can you tell which?
  13. cgaswillys
    cgaswillys
    from New Jersey
    The front axle in my Willys G***er. :D
  14. 60 Belair
    60 Belair
    finished my axle last weekend
    cool
    later Andy ​
  15. trashn'l
    trashn'l
    Here's a few in my '37.
  16. lostforawhile
    lostforawhile
    I just finished the bell crank mechanism for my choke ***embly, is behind and under the glovebox, the other lever isn't added yet,but i figured i would drill it and make it look interesting. still have to blast off the ****m blue, runs on a ball bearing, and the entire thing is aluminum, if someone looks up under my glovebox it's visible,so i wanted it to look decent. :)
  17. Bruce302
    Bruce302
    from NZ
    Here's a door off my Firebird race car. It can do with some more holes in the inner panel, but you can see that the gl*** runners and supports have been swiss cheesed, as have the seat runners, door hinges, and hood hinges. Even the door locks were sawed in half so only the bit visible outside remains. Must have saved an ounce and a bit.[​IMG]
  18. Bruce302
    Bruce302
    from NZ
  19. lostforawhile
    lostforawhile
    I got one of your pictures to work [​IMG]
  20. Bruce302
    Bruce302
    from NZ
    Thanks Lost, It worked before, but not this time.
  21. lostforawhile
    lostforawhile
    try getting a free photobucket account, thats what i use on every forum i'm on, you upload,then copy the IMG link below the picture, paste it in the thread and done. just set your pictures to a reasonable size on the site is all.
  22. Bruce302
    Bruce302
    from NZ
    Cheers, I've used imageshack before, but the photobucket must be better here. Thanks for the tip.
  23. a.y1320
    a.y1320
    This dash needed a few vents
  24. PurHell
    PurHell
    from So Cal
    I've blown a lot of holes thru stuff.. No failures sooo far...
    Anybody go a bit too far and have an "oh **** moment"?...
  25. lostforawhile
    lostforawhile
    yea a set of wiper arms.
  26. PurHell
    PurHell
    from So Cal
    "yea a set of wiper arms"
    Ha .... at least it wasn't a frame...
  27. Little Wing
    Little Wing
    from Northeast
    some old hubs
  28. 65 impala
    65 impala
    a few holes here
  29. langy
    langy
    Keeping the thread going :)
  30. langy
    langy
    Some holes with grilles
    metalhead140 likes this.
