Hollander interchange question,Desoto starter
Discussion in 'The Hokey Ass Message Board' started by sleeper, Nov 29, 2005.
  1. sleeper
    sleeper
    Can anybody with a Hollander's book handy tell me if a '49 desoto starter will interchange with a '54?
  2. Deuce Roadster
    Deuce Roadster
    My Hollander lists the 49 and 50 as the same...
    54 6 cylinder and the 54 8 cylinder starters are different from each other and the 49 - 50 also.........according to Hollander.
    Hollander only lists direct interchanges.......so it might work.........but I have only had 1 Mopar........a 1963......
    So I am so not help with the MOPAR....stuff
  3. Bugman
    Bugman
    If it's a 6 going on a 6, it should work. If it's 6 going on a V8, it *might* work, but the gear teeth may need to be interchanged, or it may bolt up completely differently.
  4. 286merc
    286merc
    from Pelham, NH
    Nope. The following 6 cyl only are direct interchange
    51-54 Chrysler
    51-54 DeSoto
    55 Dodge truck with the HM engine.
    Hollanders lists armature interchanges but you have to ID the # stamped on it.
  5. sleeper
    sleeper
    Thanks 286merc I was looking for the 6 cyl info
