Hot Rods Holley 1850’s on a 6-71 help needed
Discussion in 'The Hokey Ass Message Board' started by Nocero, Sep 25, 2019.
  1. Nocero
    Nocero
    82FF2E3A-B2B3-4319-8D83-D2158A72AB4C.jpeg D51801AD-8F98-4C74-BF05-64205882BC76.jpeg Has anyone used vacuum secondary 1850’s sideways on their 6-71?
    Having some throttle linkage issues with the rear throttle hitting the front vacuum pot.
    Any easy solution?
    It will clear with a 1/2” taller spacer on the front.
    I suppose I could make an air cleaner spacer to make the scoop sit level for the rear. But it would look strange with one carb spacer taller than the other.
    Any ideas?
  2. 427 sleeper
    427 sleeper
    That's why 1850's are usually run inline. Too many headaches... [emoji41]
    FWIW, I had better luck with 4779's mounted sideways... looks and performance wise. All depends on your combo,of course. [emoji41]
    Deuces and swade41 like this.
  3. squirrel
    I had 4777s sideways on a 6-71 for a couple decades, it worked out all right.
    Vac secondary carbs on a blower is kind of a strange thing to do.
    I also have a pair of Carter 9755 carbs on the blower now, they work fine as well.
    Deuces and 427 sleeper like this.
  4. 427 sleeper
    427 sleeper
    Call me biased, but, I feel that a Carter AFB is a Better carb all the way around. I know... Opinions... [emoji16]
    gimpyshotrods likes this.
  5. Nocero
    Nocero
    Yea I know they probably weren’t the best choice
    I listened to some poor advice unfortunately
    And they seemed like a really good deal at the time. I have to try and make them work if I can
    They came with the blower setup and were inline.
    I can put them inline if needed but it will be kind of a pain and looks goofy to me.
  6. 427 sleeper
    427 sleeper
    I might look goofy, but throttle linkage and fuel lines are waaaay easier.
    Blacktop VooDoo, swade41 and squirrel like this.
  7. squirrel
    pretty sure I have less than $200 total in the carters on mine, but I bought them a little over 5 years ago. used from ebay, then put kits and stock jets in them.
    kidcampbell71 likes this.
  8. Nocero
    Nocero
    I have a pair of edelbrock 600’s but I used a conversation kit to recalibrate them to 400’s and it required the restrictors to be epoxy’d in.
    Maybe I can get them out and sell the holleys if I have to
  9. saltflats
    saltflats
    from Missouri
    Turn the other one around.
  10. 427 sleeper
    427 sleeper
    Just for conversation sake, what are you working on? [emoji848]
  11. Nocero
    Nocero
    Lol that may cause some linkage issues
  12. Nocero
    Nocero
    31 model A coupe
  13. 427 sleeper
    427 sleeper
    A blown Model A ALWAYS kicks ***!!! [emoji41]
    Sweeeeeet!!!!
    Deuces and Nocero like this.
  14. Nocero
    Nocero
    B06E830C-B96F-40FD-8670-9437524EE07F.jpeg 17306776-5475-4BA4-AA44-D31593947782.jpeg FF9362E8-CDA1-4505-BAE0-FFB196CCFAB3.jpeg
    Here’s the current configuration
    It’s been through a lot of changes. Always wanted a blown Pontiac but for now will have to settle for a sbc
  15. toxic waste
    toxic waste
    from Iowa
    Holley 4777 and 4779 have the right float bowls for side ways mount. The holley 1850 float bowls are for straight mounting. 1850 will slosh gas and give a false fuel level.
  16. Nocero
    Nocero
    Good to know
    I think I’m just going to put them inline and try it out. This is just a street cruiser so it won’t see any drags. I’m willing to sacrifice max performance if I can get them to work.
    With all the obstacles seem to make sense
    And I already have the inline linkage.
    Apparently someone makes vacuum secondary lids that link together for tunnel ram usage anyone have a part number been searching and can’t find anything
    swade41 likes this.
  17. squirrel
    I wouldn't bother with that...blown motors are surprisingly not picky about the carbs on them. Way different game than tunnel rams
    pitman and 427 sleeper like this.
  18. 427 sleeper
    427 sleeper
    If you're not going to race it you might be surprised at how steerable they are. I got my set up from Gary Dyer in the early 90's and the inline 600's were great until I wanted more then he recommended box stock 4779 750dp's. Man was he on the money! As far as the synced vac. sec. covers, just go to the Holley website and you can find everything you need. [emoji41]
    Killer Coupe, BTW!!! [emoji106]
    Deuces and kidcampbell71 like this.
  19. Tickety Boo
    Tickety Boo
    from Wisconsin
    Hot Heads make a offset carb adapter set, part number #80559 that might allow you to jog front carb slightly to the drivers side and other one right, might allow clearance for the linkage to p***.:rolleyes:
  20. Nocero
    Nocero
    Thanks guys I appreciate all the info
  21. toxic waste
    toxic waste
    from Iowa
    I used 1850 straight on a 6-71 . They worked great. I bought secondary spring kits, big pump kit , cam kit for pumps and squirters . Always need jets too. And a lot of time testing. When it was done there worked really good.
    Deuces, saltflats and Nocero like this.
  22. toxic waste
    toxic waste
    from Iowa
    By the way , this was on a Pontiac.
    Nocero likes this.
  23. Nocero
    Nocero
    Do you remember which cam you used?
    Did you boost reference them?
  24. toxic waste
    toxic waste
    from Iowa
    I don't remember what cam . No I did not boost reference. If I did it again I would, boost reference sounds like a better way. I started out with 5 sizes bigger jet then stock and went bigger from there.
  25. squirrel
    I'd stick with stock jetting and see how it does, holleys are generally set up pretty rich out of the box...
  26. Nocero
    Nocero
    Would you change to a 50 cc acc. Pump right out of the gate or try it as is?
    Deuces likes this.
  27. squirrel
    I would leave it all stock and see how it does.
    Deuces, 2OLD2FAST and 427 sleeper like this.
  28. Deuces
    Deuces
    You might have to add a 1/4" spacer under the carb(s) for clearance.....
  29. swade41
    swade41
    from Buffalo,NY
  30. Nocero
    Nocero
    I have 1/2 phenolic spacers on already, had them from my old setup.
    Deuces likes this.
