Can anyone explain how the choke on this Holley is supposed to work? Opinions on efficiency of this type of setup? If I change to a manual choke cable should the plastic part be removed? Thanks ?
That was a Qjet replacement it would use the divorce choke that uses the choke coil mounted on the intake. If you use a manual cable you will still need the plastic part it is the fast idle cam.
