holley 600 issues!!
Discussion in 'The Hokey Ass Message Board' started by n847, May 13, 2012.
  1. alpo
    alpo
    I read on the holley site that the vacuum secondaries will only open while under a load and not just by reving up the engine while stopped. They said to clip a paper clip on the diaphram rod and push it up against the housing; then take it for a good ride. When finished, if the secondaries opened, the clip will be pushed down the rod and you can tell if they opened and how far they are opening.
  2. 61 chevy
    61 chevy
    also vacucm diaphram spring may be too strong, they make a spring kit,
  3. mustang6147
    mustang6147
    from Kent, Ohio
    You guys just said the same thing I did... LoL at least where on the same page....
    The proper way to set up a Holley, is with a vacuum guage. So you get a reading at idle, then do the math, and pick a PV... Then you take it for a ride get a cruising vacuum.... Idle Vacuum, and dead punch, and how far down the vacuum goes when you punch while cruising.....
    The pick the color spring that best fits the vacuum range.... then take her out and try it.... and then try 1 up and 1 down.... to see what the engine responds best too....
    usually averaging out, and going a little stronger on average, will get you the best drivability and performance gain....
  4. n847
    n847
    Mustang:
    I'm gonna have to borrow a better/smaller vacuum gage and tape it to my windshield and try that!
    I saw the stuff on the Holley website last night about the paper clip, I'll be trying that tonight!
  5. mtkawboy
    mtkawboy
    Its not unusual for the outer ring on the harmonic balencer to turn on the inner part. My Z/28 race car was off 10 degrees when I degreed it in. That will cause a lot of problems that will seem carb related. Just something to think about
  6. mustang6147
    mustang6147
    from Kent, Ohio
    Just be carefull... ussually its a 2 man job, one driving and one recording. You dont have to drive fast, you are more concerned at low rpm when engine is building, and so is vacuum, the drive at say 30 mph and punch it recording the reading to 45 or 50 mph no faster...
    What you ultimatelyy want to acheive is, the secondarys stay closed until the engine builds vacuum to open them, the vacuum is built by rpms, and thus the need for more fuel, which creates more HP and TQ... Its a circle...
    Stopped at a dead punch, your vacuum will drop to zero, this is why you have an accelerator pump, since at that specific moment, your engine doesnt have the ability to **** gas, through the venturies.
    Idealy but not always acheived it. An idle vacuum of about 16 to 17 psi, and a punch vacuum drop to 5 PSI
    White - Lightest
    Yellow (Short Spring)
    Yellow
    Purple
    Plain (Steel grey)
    Brown
    Black - Heaviest
    If there is a bog or hesitation when the secondaries open, the spring tension is too light, go to the next heavier spring.
    Note the spring you took out, and how it drove, that will give you a starting point.
    I am long winded, hahaha.... Trying to give out all necessary info in my brain... on a thread....
  7. n847
    n847
    I have a vacuum pump gage, could I use that to pull vacuum and see if the secondaries open?
  8. mustang6147
    mustang6147
    from Kent, Ohio
    <TABLE dir=ltr border=1 cellSpacing=0 cellPadding=7 width=471><TBODY><TR><TD height=15 vAlign=top width="17%">
    SECONDARY THROTTLE OPENING RANGES ​
    COLOR
    </TD><TD height=15 vAlign=top width="17%" colSpan=2>
    RELATIVE LOAD ​
    </TD><TD height=15 vAlign=top width="33%" colSpan=3>
    350 CID ENGINE
    OPENING RPM ​
    402 CID ENGINE
    OPENING RPM ​
    </TD></TR><TR><TD height=8 vAlign=top width="25%" colSpan=2>
    Initial ​
    </TD><TD height=8 vAlign=top width="25%" colSpan=2>
    Full ​
    </TD><TD height=8 vAlign=top width="25%" colSpan=3>
    Initial ​
    Full ​
    </TD></TR><TR><TD height=7 vAlign=top width="17%">[FONT=ENDOOD+Arial,Arial][FONT=ENDOOD+Arial,Arial]
    White ​
    [/FONT]​
    [/FONT]​
    </TD><TD height=7 vAlign=top width="17%" colSpan=2>[FONT=ENDOOD+Arial,Arial][FONT=ENDOOD+Arial,Arial]
    Lightest ​
    [/FONT]​
    [/FONT]​
    [/FONT]​
    [/FONT]​
    </TD><TD height=7 vAlign=top width="17%">[FONT=ENDOOD+Arial,Arial][FONT=ENDOOD+Arial,Arial]
    [/FONT]​
    [/FONT]​
    [/FONT]​
    [/FONT]​
    [/FONT]​
    [/FONT]​
    Yellow* ​
    [/FONT]​
    [/FONT]​
    Lighter ​
    [/FONT]​
    [/FONT]​
    1620 ​
    [/FONT]​
    [/FONT]​
    5680 ​
    [/FONT]​
    [/FONT]​
    1410 ​
    [/FONT]​
    [/FONT]​
    4960 ​
    [/FONT]​
    [/FONT]​
    Yellow ​
    [/FONT]​
    [/FONT]​
    Light ​
    [/FONT]​
    [/FONT]​
    1635 ​
    [/FONT]​
    [/FONT]​
    5750 ​
    [/FONT]​
    [/FONT]​
    1420 ​
    [/FONT]​
    [/FONT]​
    5020 ​
    [/FONT]​
    [/FONT]​
    Purple ​
    [/FONT]​
    [/FONT]​
    Med. Light ​
    [/FONT]​
    [/FONT]​
    1915 ​
    [/FONT]​
    [/FONT]​
    6950 ​
    [/FONT]​
    [/FONT]​
    1680 ​
    [/FONT]​
    [/FONT]​
    6050 ​
    [/FONT]​
    [/FONT]​
    Plain ​
    [/FONT]​
    [/FONT]​
    Medium ​
    [/FONT]​
    [/FONT]​
    2240 ​
    [/FONT]​
    [/FONT]​
    8160 ​
    [/FONT]​
    [/FONT]​
    1960 ​
    [/FONT]​
    [/FONT]​
    7130 ​
    [/FONT]​
    [/FONT]​
    Brown ​
    [/FONT]​
    [/FONT]​
    Med. Heavy ​
    [/FONT]​
    [/FONT]​
    2710 ​
    [/FONT]​
    [/FONT]​
    8750 ​
    [/FONT]​
    [/FONT]​
    2380 ​
    [/FONT]​
    [/FONT]​
    7650 ​
    [/FONT]​
    [/FONT]​
    Black ​
    [/FONT]​
    [/FONT]​
    Heavy ​
    [/FONT]​
    [/FONT]​
    2720 ​
    [/FONT]​
    [/FONT]​
    Not Fully Open ​
    [/FONT]​
    [/FONT]​
    2390 ​
    [/FONT]​
    [/FONT]​
    Not Fully Open ​
    [/FONT]​
    [/FONT]​
    </TD></TR></TBODY></TABLE>
  9. mustang6147
    mustang6147
    from Kent, Ohio
    the lines didnt match up but the low rpm is initial, and the high is full... I just stumbled on this, and it may help you factor in with vacuum readings
  10. Dooley
    Dooley
    from Buffalo NY
  11. n847
    n847
    OK took a drive and the secondaries are opening, and it moved the clip a good portion of the way down the shaft. Does any one know what spring they come with from the factory, just out of curiosity! The car ran great around town for about a half hour.
  12. 52Poncho
    52Poncho
    They come with the plain spring from the factory.
    See post #38
