Technical Holley 885 carb problem
Discussion in 'The Hokey Ass Message Board' started by 1951Merk, Jan 30, 2016.
  1. 1951Merk
    1951Merk
    Hey all....my 51 Mercury is still running the Holley 885 carb...I have developed a leak at the fuel inlet fitting...I have replaced the fitting the copper washer multiple times and slowed for a little bit but now I'm back to where I started. Any thoughts as to what I am doing wrong or any tricks on fixing it? Thanks....still learning all of this stuff as this is my first cl***ic car....
  2. Mike51Merc
    Mike51Merc
    Yeah, that's a weak spot on those carbs. The threads get stretched and don't seal properly. If you overtighten it will get worse. You might try some gasoline-proof thread sealant, or eventually drill and tap it for a new fitting, or get another carb that you hope is in better shape, or swap carbs for something different.
