Technical Holley 94 2x2 Jet Size?
Discussion in 'The Hokey Ass Message Board' started by ironhill, Jul 5, 2014.
  1. ironhill
    ironhill
    from Simms, MT
    Hey guys, just curious for those of you who run 2 94's what you guys are running for jet sizes? I'd guess the strombergs might be close too?? I just put in a bone stocker 350 chevy in my coupe with a dual 94 setup on it and boy it runs great but it's running alittle rich. The smallest pair I had on hand were 52's which seemed alittle big but was all I had. Thanks for any info!
  2. Have a flathead running two 94's. The jets in them are 51's. I live on the coast and all of the carburetors I have torn apart run 50's, 51's or 52's. If you are at a higher elevation then a smaller jet would probably be better.
  3. ironhill
    ironhill
    from Simms, MT
    Thanks that's sounds about right! I'm fairly high up.
  4. It may not be your jetting, the numbers sound about right, your power valves may be opening too soon,
    you should be running 3.5 or 4.5's with duals.
  5. wbrw32
    wbrw32
    What kind of intake manifold are you running??? I dont believe I've ever seen a 2x2 manif for a small block..all I have ever seen are 3x2...
  6. He could be using one of these.....
  7. ironhill
    ironhill
    from Simms, MT
    Yes running an adapter, messed with it some more today. Actually noticed extra fuel in the rear carb after shut down, pulled the top off and sure enough a small piece of what looked like Teflon tape (it don't use that stuff on hot rods) was stuck in the seat, cleared that up and she seems to be running pretty clean! Thanks guys!
