Technical Holley 94 3x2 Setup, Boosters Siphoning Gas
Discussion in 'The Hokey Ass Message Board' started by Pocket Nick, Mar 17, 2016.
  1. gimpyshotrods
    gimpyshotrods
    You'll get it.
    Traditional?
  2. And then...we find a small sliver of br*** just chilling on the needle. And second inspection found one plugged port on the nozzle crossover. I adjusted the float levels 1/16" lower to put more pressure on the needle and seat just in case. At least the PV p***ed the leak test of filling the bowls and watching them on the bench for any dribbles. None found. Getting closer to fixing this ********. ImageUploadedByH.A.M.B.1458529985.416019.jpg ImageUploadedByH.A.M.B.1458529998.398753.jpg
    deadbeat, hipster and gimpyshotrods like this.
  3. gimpyshotrods
    gimpyshotrods
    Any news?
    Traditional?
  4. As a matter of fact yes, just got a set of new crossover tubes and nozzles for the center carb installed 20 minutes ago, the air bleeds in the main circuits were leaning it out. Runs hard and now we wait to see if it floods. Took
    It for the maiden voyage and it is a scary twitchy car. Lights tire with minimal input!
  5. gimpyshotrods
    gimpyshotrods
    What is the caster set at?
    I had plans to put an anti-sway bar on the front, but I never got the time to do so. I will see if I can dig up the drawings.
  6. Ah hell, its like 12 degrees. Steep I know. Goes reeeeaal straight though. I'd have to cut the wish bones and rotate them.
