Technical Holley 94 carb height
Discussion in 'Traditional Hot Rods' started by vetteson, Apr 19, 2022.
  1. vetteson
    vetteson
    Is the Chandler Groves Holley 94 carburetor any shorter (lower) than other 94 series carb? If not is there a "shorter" version of the 94 (I have some under-hood clearance issues).
  2. goldmountain
    goldmountain
    Mine measures 6" tall. In previous posts, Moriarty's Corvette runs a ManaFre intake with Rochesters which seem to clear.
  3. clem
    clem
    I would doubt that there would be significant difference between any of them.
    What about a lower profile or remote air filter, - would that help you out ?
  4. All 94 type carburetors are about the same height. The ECG type tend to be taller.
  5. wheeltramp brian
    wheeltramp brian
    You could always mill the top off if you don't need filters
  6. clem
    clem
    that’s what I thought, but the ‘94 and ecg I measured were both 146mm high, approximately 5&3/4” (25.40mm = 1”).
    6” as mentioned above = 152.40mm.
    Some of the later ones may be taller but I wasn’t going to crawl in the attic to find more to measure.
    I don’t have a Chandler Groves one, but I doubt that there would be significant difference there as I always thought that the later ones were just a copy (knock-off )
