Technical Holley 94 on Offenhauser 4x2 - can you or how do you set up kickdown for TH350
Discussion in 'Traditional Hot Rods' started by Joey L, Oct 4, 2022.
  1. Joey L
    Joey L
    Considering this manifold setup for my 327. It runs and electric fuel pump and my biggest concern aside from tuning the carbs is setting up the kickdown for the TH350 auto on the truck. Before I drop the coin for the setup I want to make sure I can get this to work.
  2. sdluck
    sdluck
    350 can be driven without kick down with no damage,get the linkage hooked up and mount the cable off the linkage.
  3. Joey L
    Joey L
    Yeah I know - but I prefer it with the kick down. I would ***ume you would mount it to the left side rear carb linkage. I just want to make sure I can do it before dropping the money for this setup as it isn't cheap.
  4. wheeltramp brian
    wheeltramp brian
    On multiple carb setups with the auto trans I've cooked it through the firewall to the gas pedal with some bracketry
  5. Joey L
    Joey L
    It currently has a kick down on the Edelbrock 600 on the car now. I would ***ume that bracket won't work - and I've been looking online - but is there a specific bracket for the 94's or will I simply have to make my own?
  6. 26Troadster
    26Troadster
    i don't know all the years chevrolet put the kick down cable in the firewall with the gas pedal but the ot 1973 impala had it. the pedal had a double hole, and a different style cable that hooked into the firewall just above the throttle cable. if i remember right no brackets either.
  7. sdluck
    sdluck
    what manifold and carb linkage? Pictures would help.
  8. Joey L
    Joey L
    Current carb and manifold are Edelbrock. The TH350 is shifted by a Lokar shifter. Not sure of the brand of the kickdown. The first pic is my existing setup. The second is the setup I'm considering buying.
  9. sdluck
    sdluck
    Make a bracket to mount off the middle 2 carbs and hook it to the linkage.
  10. Joey L
    Joey L
    I need to take a look at the Holly 94 linkage and see if there is a way to hook up to it. Mounting the cable to the manifold will be pretty easy, but getting the right amount of leverage to pull the cable upon throttle application might be tricky.
  11. sdluck
    sdluck
    pull on it by hand,there is very little tension.
