I've got some 94s I need to set up for a 6 carb 471 blower top. Where is the best place to get longer throttle shafts, arms etc to make these work? Can I rebush the throttle housings myself? Thanks Brad
the hamb's own hotrodjosh runs www.97heaven.com or you could try www.vintagespeed.com -as far as worn throttle bodies go you can slip tiny o-rings on both ends of the throttle shaft on the outside,that's what i did on mine,and it worked fine.94 throttle bodies don't have bushings,so you'd have to drill'em oversize,press in some bushings,and then use a reamer to finish to the right size,i used to do SU carbs and that was the process for them-george
Speedway has longer shafts, ****erflies also. The shafts are slightly oversize so you can clear up any slop you may have.
