Holley 94's or 97 strombergs for my build
Discussion in 'The Hokey Ass Message Board' started by willbierfarms, Jan 19, 2014.
  1. willbierfarms
    willbierfarms
    from palmyra mo
    Been working over my intake manifold getting it where it will work with either 94 holleys or strombergs well which is the better choice I can get either brand easily but do t have any idea of the pros or cons of either carb
  2. 57Custom300
    57Custom300
    from Arizona
    94's & 97'S preform about the same. 94's work good & there's plenty of them out there for a decent price. 97's are a bit harder to pick up but you cant beat the "cool" factor of them. Just make sure you have deep pockets for 97's
  3. Tim333
    Tim333
    I have a 97 for sale if you need one.....
  4. Mike51Merc
    Mike51Merc
    Strombergs are more expensive and some people consider them more desireable.
    Other than that, the arguments over which is "better" go on forever, almost as much as radial versus bias-ply tires.
  5. Here's a couple of 94"s that are going on a 3x2 setup (Y-Block)
  6. Dreddybear
    Dreddybear
    97's are easier to tune for multi carb setups due to the mechanical power valve.
    94's are a little bit harder but are less expensive.
    I run 4 94's with all 3.5 power valves and straight linkage. I tweaked the accelerator pumps to come on properly. It runs like a bat out of hell right off the line.
  7. DERPR30
    DERPR30
    from HARVEY LA
    Here is a pic of my 6 97's
  8. chuckles0
    chuckles0
    Is that a 153 chevyII. (or 'Mecruiser120,?)Did you make those intakes?
    That's what I have (home made 2bl.intake for a Holley 350/500.327 chevypistons..
    6 rebuildables.1-11/16'' and 15/16".
    PM..me
  9. willbierfarms
    willbierfarms
    from palmyra mo
    Here are some more pics of my intake I don't have the adaptor plates mounted yet ill show some pics when I do
