Technical Holley carb - does it exist?
Discussion in 'The Hokey Ass Message Board' started by SDS, Apr 14, 2026 at 7:50 PM.
  1. SDS
    SDS
    Does a simple square bore, vacuum secondary, Holley 650 with short float bowls exist?
  2. RodStRace
    RodStRace
    I think the 600 is typically vac, 650 is spread and/or mechanical.
    Also ***ume you mean side hung float 4160 style.
    https://www.holley.com/products/fuel_systems/carburetors/
    The brawler has 650 square bore, vacuum secondary, but is 4150 style.
    there are square vac 4160 style but they are 600. Is the 50 CFM the issue?
  3. HEATHEN
    HEATHEN
    from SIDNEY, NY
    No, but I've heard countless people call an 1850 600 cfm carburetor a "Holley 650".
    squirrel likes this.
  4. squirrel
    yeah, this is the typical old fashioned "cheap" holley 4bbl carb, it looks a bit different than it did 60 years ago. And the price went up while you weren't looking.
    19Eddy30, Moriarity and HemiDeuce like this.
  5. jimmy six
    jimmy six
    A lot of the early ones were listed as 585 cfm which were used on 271hp 289 K code Mustangs as performance carbs. Mines is from a 60’s International big truck…… so much for $$$$$ high performance.
    Today unless you want this exact Holly you are better off with an Autolite look-a-like that Holley made and now Holley makes them for Summit as 500, 600, and 700 cfm and are reasonably priced.
    19Eddy30 and Budget36 like this.
  6. swade41
    swade41
    from Buffalo,NY
    650 spread bore
    Screenshot_20260415_014205_Gallery.jpg Screenshot_20260415_014255_Gallery.jpg
    And 600 cfm (1850)
  7. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I believe '83 - '85 Mustang GTs were 630 cfm Holleys. Not sure if that is wet flow or dry flow.
    19Eddy30 likes this.
