Holley carb help
Discussion in 'The Hokey Ass Message Board' started by dirtfan50, Jun 28, 2012.
  1. dirtfan50
    dirtfan50
    from Kentucky
    Guys im trying to figure out what carb this. 4224 is on each metering block. All carbs i see only has one fuel inlet and one metering block . As you can see in my picture it has 2 metering blocks.
    Thank you for any help
    <br>[​IMG]
  2. 55driver
    55driver
    The 4224 is the 660 cfm mechanical secondary carb mostly used on tunnel ram intakes.
  3. landseaandair
    landseaandair
    from phoenix
    660 center squirter.
  4. landseaandair
    landseaandair
    from phoenix
    Haha, had to move the screen over so far with the huge pic, I didn't even see 55driver's post.
  5. dirtfan50
    dirtfan50
    from Kentucky
    Why is it when I look that up I only see one metering block on the front of the carb?
    Thank you for the help
  6. dirtfan50
    dirtfan50
    from Kentucky
    Sorry for the pic size.. I couldnt get it to load and had to have my daughter help...
  7. landseaandair
    landseaandair
    from phoenix
    They were most likely converted with a kit. Came with longer bowl screws and transfer tube.
  8. dirtfan50
    dirtfan50
    from Kentucky
    I wonder if I would need a special rebuild kit because of the extra metering block.
    Sorry for the stupid questions but just want to be sure.
    As always thank you for the help.
  9. railroad
    railroad
    You can buy the bowl and block gaskets separate. You may have to also buy a secondary power valve. If you need a whole kit, buy it and then buy the addition pieces individually.
    Just noticed they are sitting on a s/c, may not have power valves.
  10. dirtfan50
    dirtfan50
    from Kentucky
    I took the carbs apart and cleaned the **** from tham and didnt see any power valves ?
  11. railroad
    railroad
    Should have a screw in plug in the lower center of each metering block.
  12. dirtfan50
    dirtfan50
    from Kentucky
    No power valves in either end
