Holley carb issue
Discussion in 'The Hokey Ass Message Board' started by A53fly, Feb 8, 2011.
  1. A53fly
    A53fly
    My truck starts up fine but when i put it into gear it bogs down and dies.
    I adjusted the idle a bit faster and now when i put it into gear it bogs for a few seconds then catches up with itself and runs.
    Something is not right, what would cause this?
    Thanks in advance.
  2. snap daddy
    snap daddy
    from Omaha, NE
    Could be a dozen things causing that. Is it a fresh rebuild? New carb? Need a little background.....
    Possibilities: Vacuum leak, idle mixture not right, float level not right, bad power valve, etc.
  3. Abomb
    Abomb
    To be honest, my first thought was slow timing....just double check your intial timing before working on the carb.
  4. themoose
    themoose
    Whats your vacuum at idle?
  5. The Shocker
    The Shocker
    Sounds like a va***e leak to me .More info would be helpfull (engine ,carb size ,dist type ,etc.)...
  6. A53fly
    A53fly
    Thanks everyone.
    Its a 350 and a new carb that is under a year old. My truck ran great before but I then it sat for a couple months, from that some nasty stuff built up in the primary side of the carb. I cleaned out the bowl and metering block, but I did not change the power valve. I have not put a vacuum gauge on it, although I don't think there is a leak cause there was not a problem before. I never messed with the mixture ratio and the timing was done about a month before I let the truck sit. I have checked to make sure the float level is correct.
    It will run fine until I put it into gear, then it'll bog down and die, unless the idle is set higher.
  7. Dreddybear
    Dreddybear
    A leak is easy to find with some carb spray. And double checking timing isnt a bad idea.
    Also, sorta unrelated, but similar sounding... you mention that it sat for a while. I have seen recently alot of older cars that sit around have been having these random fuel-jellying problems cause of the newer ****ty fuel. A carb rebuild gets rid of it in the carb, but people will sometimes overlook the filters and (in one case we had at the speed shop) the foam in the fuel cell. We cleaned that car a couple times before realizing that the fuel cell foam was contaminated and kept gunking up the gas. USE STA-BIL if it's gonna sit.
  8. terryble
    terryble
    from canada
    Truck sat for awhile, carb dried out, no other changes, cleaned carb, now bogs? Accelerator pump and/or power valve.
  9. A53fly
    A53fly
    Thanks fellas. I have a fuel cell with foam in it, which i will remove and inspect. Also, i will change the power valve.
