Technical Holley carburettor
Discussion in 'The Hokey Ass Message Board' started by Harleyv89, May 29, 2023.
  1. Harleyv89
    Harleyv89
    Hi,
    i found a original holley 650 2 barrel carburettor. Some people have told me they are hard to find? (Australia) can anyone give me some information? I cant find anything. Are there any rare carburettors i though they made heaps of most models.
    Any information would be good. Thanks
  2. X38
    X38
    Deuces likes this.
  3. Harleyv89
    Harleyv89
  4. X38
    X38
    I think they'd be **** on the street.
    Every 302 Windsor I ever bought had a 350 2 barrel on it. Never ran them.
  5. Harleyv89
    Harleyv89
    Its a 650 2 barrel not 350
    Deuces likes this.
  6. X38
    X38
    I realise that. That's why I posted links to them in my first response.
    I was merely indicating how common the 350 size is as opposed to the 650. But I'll stay out now.
    Budget36 likes this.
  7. Budget36
    Budget36
    I recall talk of using large 2bbl carburetors in either circle track, dirt track? Something like that.
    Internet chatter, so has to be true;)
  8. alanp561
    alanp561
    I ran Holley single 4412 2 bbl. carbs at some dirt tracks in central CA in the 60's. Bought them brand new for $27.00 and milled the air horns off of them. Worked really well on 390 Fords.
    Deuces likes this.
  9. Budget36
    Budget36
    How much flow were they rated at? Like the one the OP posted or different?
  10. Jmountainjr
    Jmountainjr
    The 500 & 600 cfm Holley two barrels were mostly used in two barrel restricted circle track cl***es. The early ones had short velocity stacks like the early Dominators. Not exactly rare and not sure what the use demand would be beyond racing.
    onetrickpony and Deuces like this.
  11. alanp561
    alanp561
    500 CFM
  12. Budget36
    Budget36
    So designed for at or near WOT?
    (never get to old to put something in the memory bank).
  13. alanp561
    alanp561
    I actually ran one on a 65 Galaxie family grocery getter while I was re-building my 4 bbl. It was pretty streetable and didn't seem to use much more gas than the 4 bbl did.
  14. Budget36
    Budget36
    I’m sure you kept your foot out of it too;)
  15. Deuces
    Deuces
  16. alanp561
    alanp561
    Holley 4412 500 CFM 2 bbl. Not much difference exterior wise.
    Budget36 and Deuces like this.
  17. Deuces
    Deuces
    The 650 has no venturi boosters....:confused:
  18. gimpyshotrods
    gimpyshotrods
    A true 650cfm 2-barrel would suffer to meter fuel at low RPM.
    This is exact why 4-barrel carburetors exist. Those have equal, or smaller primaries to meter fuel at lower RPM, bringing in the rest at higher RPM, only.
    Deuces likes this.
  19. gimpyshotrods
    gimpyshotrods
    It has annular discharge boosters.
    Deuces and jimmy six like this.
  20. saltracer219
    saltracer219
    It has annular discharge venturi's, no actual boosters but a big ***ed accelerator pump to make up the difference. They were a race only deal.
    Deuces likes this.
  21. ClayMart
    ClayMart
    I'm really not that familiar with these Holley 2bbl carbs. But if Holley sold a model of these primarily for circle track racing, did they all come equipped with a manual choke like the ones pictured above?
  22. jimmy six
    jimmy six
    I’ve got 3 of the Brazwell’s which bored out the stock Venturi’s and boosters then inserted aluminum annular discharge Venturi’s. I believe Holley sued them with a stop and desist order. They were said to be more cfm than the Holley. The choke towers were also removed. They have been used a Bonneville on both my GMC 6 and the flathead powering Jimmy Stevens street roadster. IMG_0183.jpeg IMG_0186.jpeg
    Deuces likes this.
  23. X38
    X38
    Be warned, the OP will jump on your *** if you mention anything other than a 650!
  24. Deuces
    Deuces
  25. gimpyshotrods
    gimpyshotrods
    Must have been awful on the street!
    Deuces likes this.
