Holley Float Bowls
Discussion in 'The Hokey Ass Message Board' started by Dooley, Apr 20, 2009.
  1. Dooley
    Dooley
    from Buffalo NY
    Are Holley 4150 double pumper float bowls interchangeable?
    I want to run my fuel feed on the drivers side and would have to swap the primary and secondary bowls to get the feeds on the right side (actually left side)
    They appear similar and the accelerator pumps woudl line up as well.
    Anyone?
  2. scottybaccus
    scottybaccus
    Should swap right over so long as it's a double pumper. It's the accelerator pump that hoses you up on a single squirter.
  3. Shifty Shifterton
    Shifty Shifterton
    I've tried to do it and found it was too much **** on one side with the throttle linkage. With a couple minor bends you can flip those chrome premade fuel lines to feed from the back of the p***enger side. Totally the way to go if you're doing rear feed IMO. Those big float bowls will hang so far over the intake nobody could see the little extra amount of fuel line going to the p***enger side.
    Now whether or not to use those chrome fuel lines is a whole nother thread :) Good luck
