Hot Rods Holley list 1844 2 barrell carb info,
Discussion in 'The Hokey Ass Message Board' started by tommyd, Jul 5, 2014.
  1. tommyd
    tommyd
    from South Indy
    I've been searching for this info with no luck. I have come up with the Edsel/Mel application for this carb but would like to know the c.f.m. I have found a few threads that say they are early sbf tri-power friendly but looking for a little more info. Thanks in advance, Tom.
  2. tommyd
    tommyd
    from South Indy
    No-one? chirp,chirp,chirp,
  3. The 1844 is a 2300 series carb that is used on a lot of FOMOCO engines.
    It is rated around 350 cfm, depending on the ventrui size that is cast in the side of the housing.
  4. tommyd
    tommyd
    from South Indy
    Thanks for the reply Rick. I have a tri-power that has two of these {one on each end} and a 4412 in the middle so that's a LOT of cfm! I plan on trying to run mostly on the 500 center carb as its just the tri-power look I was after.
