Holley Sniper Temperature Sensor
Discussion in 'Off Topic Hot Rods & Customs' started by knuckle44, Sep 25, 2025.
  1. knuckle44
    knuckle44
    my 57 Fairlane has a Holley Sniper system, and it has a 312ci Y block motor. The temperature sensor is in the heating hose, which means I have to run the heater for the sensor to read accurately. Any suggestions for making this work without running the heater?
  2. pprather
    pprather
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    Moved to the off topic forum, the antiquated forum is for non automotive 1965 and older collectibles....
  4. squirrel
    it needs the temp of the coolant in the engine, not the coolant that's going other places...
    Pictures of the engine might help, since some of us might not remember back to when we worked on a Y block last.
    ekimneirbo likes this.
  5. miker98038
    miker98038
    I drilled and tapped the intake just behind and to the drivers side of the stat. Double check for clearance inside first, it’s tight. That’s about the only place to get into the Yblock for that. There’s a bung in the head behind the distributor but I’ve never seen anything that would fit there and clear the distributor. Given the water flow in the Yblock, you really want it up at the stat housing anyway.
    squirrel likes this.
  6. RodStRace
    RodStRace
  7. squirrel
    ...because their tech guys know all about Y blocks :)
    but maybe they have encountered this before, and have a good suggestion. They also read their own forum, and answer questions there.
    rockable likes this.
  8. miker98038
    miker98038
    It’s not that I don’t respect Holley, but this was a fairly recent subject on yblocksforever. It’s been working on my old Accel unit for 14 years, and it’s Ted Eaton’s usual location for any second sending unit.
    If the Holley sensor is really small you might get into the little byp*** hose from the stat housing to the water pump, but that’s another challenge.
  9. fastcar1953
    fastcar1953
    Where's the original sender location? Get a adapter for it?
  10. 19Eddy30
    19Eddy30
    from VA
    @knuckle44
    You need coolant to move
    across ,around Sensor , Not just dead head .
  11. twenty8
    twenty8
    You should change the sensor location.
    This is from the Holley Sniper instructions.
    COOLANT TEMPATURE SENSOR INSTALLATION
    Install the Coolant Temperature Sensor into a 3/8” NPT coolant p***age in either the intake manifold or cylinder head. Do not overtighten or damage to the cylinder head or intake may occur. It is best to drain the some of the coolant before the sensor is installed. Use thread sealer or a small amount of thread tape. Do not install the sensor in the thermostat housing, or in an area that will not see a constant flow of coolant.
    Full instructions here: https://do***ents.holley.com/199r11031r.pdf
  12. Mike Lawless
    Mike Lawless
    I have a bit of experience with temp sensor location differences. Not a Y block tho. I reckon the same logic applies.
    When I first put EFI onto Ol ' Furd's inline six, the only location available was the back of the block just below the head surface. I shoulda got one of those top rad hose thing-a-ma-bobs to run it there. I chase non existent t-stat problems for months. During cold months, it would never get up to proper run temp with the sensor there. That situation continued, till I found a t-stat housing with a threaded heater hose outlet, rather than the cast ****** that mine and all others I has seen had. This allowed the sensor to be located just before the t-stat. So the EFI was getting into normal run mode much quicker, and made a significant difference in short distance fuel mileage.
    So, I swapped over to that and just like that, I was getting proper temp readings that are so critical to the proper performance of the EFI.
    It's OK to put it in the heater hose connection on the outbound leg out of the crossover, or just before the t-stat. As close to the t-stat housing as possible. You want heated coolant as close to there as possible. If it is after the t-stat, the EFI will be in cold run mode until the t-stat opens.
    And just for information sake, there is a 20° difference in temp reading between the two locations noted above. The one on the rear of the block sees coolant temp pretty much out of the bottom of the rad after it has been cooled. During hot months, it evens out, but in cold months there is always a big difference.
    ekimneirbo and pprather like this.
  13. fastcar1953
    fastcar1953
    I had to moved mine to the head. The t stat area showed 140 degrees. The head was 175 degrees. weston.jpg
    ekimneirbo and loudbang like this.
  14. Use the port at the top rear of the drivers side cylinder head.
    pprather likes this.
