Technical Holly 94 idle mixture screws
Discussion in 'The Hokey Ass Message Board' started by StefanS, Feb 26, 2026 at 12:02 PM.
  1. StefanS
    StefanS
    from Maryland
    How the hell are you guys keeping these things from vibrating and turning out? I took the shoebox for a drive today and smelled nothing but gas. I turned the screws in to lean it out and they both went in a full turn. When I initially set them they were out just over one full turn.
    EDIT...I found my old screws, stretched the springs AND added a washer to each and the still turn super easy. Maybe my carb base is just worn
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Stiffer springs, maybe?
  3. StefanS
    StefanS
    from Maryland
    I contacted Vintage Speed to see if he had any. Where else would be a good place to find them? I took a zip tie around both of them and tightened it down snug but I'm not sure if that'll work. I was afraid to go too tight and bend them inward towards each other
  4. 1952henry
    1952henry
    Might be able to find some in your hardware store. Take yours in for comparison. You did have springs? Haven’t heard of them not working.
  5. StefanS
    StefanS
    from Maryland
    Yeah I used the new springs that came with the Vintage Speed rebuild kit. As a matter of fact I wonder if I don't have my old springs still maybe I can toss those Back on
  6. custom_lettering
    custom_lettering
    from Wall, NJ
    Can you stretch the springs a little longer so when you compress them they'll have a little more tension?
  7. Ziggster
    Ziggster
    Maybe add a washer to compress the springs a little more.
  8. StefanS
    StefanS
    from Maryland
    It definitely wouldn't hurt to try
  9. StefanS
    StefanS
    from Maryland
    I'm not sure if there's enough space on the carb base to put washers in there but it's definitely worth looking into
  10. Ziggster
    Ziggster
    Maybe try to sand the ends of the springs with some course grit paper. That might make them “grab” better and stop the mixture screw from turning.
    nochop likes this.
  11. leon bee
    leon bee
    Why not just a little dot of blue loc***e?
  12. StefanS
    StefanS
    from Maryland
    It's funny you say that. I Googled if loc***e was fuel resistant about an hour ago and read that the blue IS so I'll be picking some up tomorrow
  13. leon bee
    leon bee
    Just a little bit. And let it sit dry for a while.
